Tscott
I bought a trailer mounted 10kw military surplus generator for the farm and now I need to figure out how to connect it to the house. Based on my research, these units are very underrated and are closer to 15kw capacity. I plan to leave it on the trailer so I can move it around the farm if needed but its main purpose will be as a backup for the main house. Since it will be mobile I'm not sure the best way to connect it.
Would you give up some generator capacity and wire a 60A plug and breaker or possibly even a partial house transfer switch mounted in the garage? Or would you size the circuit for the generator max output of approximately 70A and hard wire it in every time you needed to use it?
A third option would be to use a 70A or 80A pin and sleeve type socket but they are pretty pricey so I'd like to avoid that if at all possible.
I think the simpler solution is to use the 60A plug but I do want to make sure I can power the air conditioner (30A circuit) as well as the refrigerators and all the smaller appliances at the same time without tripping the breaker. I'll give up the use of the washer, dryer, and oven for the use of the AC. We will exercise load management so in an extended outage we will have to switch loads around if we want to run the washer and I'm pretty sure we would have to shut most everything else down to run the dryer so we would probably just leave that off line and rig up a cloths line.
After typing this, I'm definitely leaning towards the 60A circuit with a plug but I'd still like to hear your input.
Tom
Tom
