potentz
I am getting ready to run power to my shed and I also have my Satellite Dish and Internet Antenna mounted on the shed. The distance from the shed to the house is 100'. I am going to rent a ditch digger and was planning on digging a 18'' trench. I am going to run the 10-3 power wire in a 1'' conduit and I am going to run the RG6/CAT 5 in a separate 1'' conduit.
Question is, can I run both conduits in the same trench or will I still risk having interference with running parallel them in the same trench? One electrician told me I would be fine and another electrician told me to dig to seperate trenches 18'' apart from each other as the PVC pipe is not adequate enough to reduce the interference.
I don't mind digging another trench if that is necessary; however, I don't want to do if it is not necessary. Any help would be appreciated.
Thanks
Thanks
