bulletpruf
Fellas -
Have had a Miller 211 for a few years and just used it for the second time today. Welded on a chassis stiffener on my Alfa Romeo. Went ok, but there are a few things that I could use some help with.
-I was welding chassis stiffeners on my 72 Alfa Romeo. The stiffeners are 16 gauge plates that have numerous holes drilled so you can plug weld. The perimeter is supposed to be welded, too.
http://www.alfaholics.com/race-part...alfaholics-chassis-leg-stiffening-kit-105115/
So, I stripped it all down to the bare metal and then painted the plates front and back with weld-through primer. Also painted the area on the car where the plate was welded, too, of course.
I was using .024 wire and 110 volts. You can't use the automatic settings with .024 wire; needs to be .030 or .035.
Welder was set up according to directions. It seems to be working fine.
The plug welding wasn't as easy as I thought it would be. Had to do some touch up work and also blew through in 2 spots. On the perimeter welds, I did pretty good when I was able to weld in a decent position. Think I was getting plenty of penetration based on what I was seeing.
See below for what I ended up with. I did a lot of grinding, of course. Pretty much all of the welds were sitting proud of the stiffening plate.
So, my questions --
-If you are welding 16 ga steel to 20 ga steel, what settings do you use? Settings for the thicker one? Thinner one, or do you split the difference?
-Should I go with .030 wire? I realize .024 is better for thin metal, but would be nice to use one size wire and just adjust my technique a bit.
-Should I use 220 or 110 voltage? I have both in the garage and the machine will work with either.
-What do you use to clean up ugly welds? I used a 4.5" grinder to grind the welds flat, but I need to work on the perimeter welds and the 4.5" grinder won't get in there. I have a small angle grinder, but not sure what attachment I should use on it. I have also heard that sandblasting can help some, too. This won't be a show car, but I really do want to clean up the welds so they're uniform and not noticeable.
Thanks!
Scott
So, my questions --
Thanks!
Scott
