iagsxr
I've had this rolling around in my head for a while. Was having a hard time visualizing all of it then the other day accidentally ran over a roll of painter's tape with my forklift so it wasn't good for anything else.
It's 6' × 12'. The width is pretty much set in stone as I ordered a 70" spring center axle today. Right now the tool box is 36", runners 9'. Those dimensions are subject to change. The double lines are 2" × 2" × .095. The wheel runners will be .095" diamond plate with a break on the inside edge down 2".
The ruler is axle location at 60%. I may scoot it forward as the toolbox will about double the weight of the trailer. You can see from the last photo 9' runners will be tight. The box may lose 6", runners gain it.
The generator will go on the tongue. That makes a jack a little bit of a cluster. Kicking around a new Honda generator just because of their smaller overall size.
My goal is under 2500lbs car/trailer/tools/spares. The car weighs 770-ish without me in it. 470 on the rear wheels. Rough estimate the trailer will be less than 800.
