mrjaw14
Greetings,
I’d like to hear you guys’ opinion on a cooling system vacuum refilll tool like an airlift.
There are two models I’m looking at right now:
Original AirLift: http://www.uview.com/index.cfm?DSP=...oryID=1330&pagepath=Products/Cooling&id=45700
Airlift II: http://www.uview.com/index.cfm?DSP=...oryID=1330&pagepath=Products/Cooling&id=45700
I know that the original AirLift is a tried and true product, the new Airlift II seems like an economy model because it doesn’t tighten down to the rad fill neck like the original it’s all plastic with cheaper valves. Having said that, it also seems like it’s upgraded design that allows purging of the fill line of air where as that’d be more difficult on the original version.
I’m really conflicted on what to buy. What’s driving me to get this is newer pressurized cooling systems. I have a Pontiac G6 that I just did a drain and fill on and I’m having a hack of a time getting all the air out. The needle stayed right around 200 degrees before I did the drain and fill, and now it struggles to get to 200 and stay there. Either there’s air in the system, or the T-Stat is stuck open. I was worried about an air lock and coolant not circulating causing an overheat.
I’m also about to do a newer F250 that has both the pressurized type and a standard type, and I sure don’t want to introduce issues into that.
If there’s another product other than AirLift that you guys think works better that’s not 2x the price please let me know.
Also, those of you who have vacuum cooling system refill kits I’d like to know your tips and tricks. I hear that reverse fill systems can be difficult. What’s you guys’ experience with these tools and how well do they work?
