Sooo, did you get dryer sheets and crackers???
Do you have a link to that kit? ThanksThese arrived yesterday, problem is I have no idea how to use them. I need to go through the panel replacement thread again. Watch some videos.
German?
German?
Maybe 20-30 years ago. Far more disposable now. Best thing you can do to it is spend 10 minutes at the end of every season wiping it down with a rust preventer.
Rebranded NWS.
Yes, you can see German stamped on the first 2 pliers.
Rebranded NWS.
German?
They look just like NWS pliers, maybe, if the guess is correct, they are very good pliers![]()
Are the needle nose Knipex? Also, who makes the heavy duty picks?
got a pn handy for those crimpers? Thanks.
Recently I saw someone purchased a Craftsman set of ball end hex sockets with wobble extentions included in a blow molded case... I have neither and could use them... I don't plan on cranking the hex sockets ... i have others that are much stronger... ie SnapOn... but they are not ball end.
I also blew up my pin nailer and didn't feel like fixing it to reuse as my primary so I purchased the one I originally wanted a Senco ... it goes to 1 3/8"... they have a model that goes to 2 inches but there is no way I would need to "PIN" something with something that long... I have finish nailers that work for that.
I needed a hammer end prybar the other day... I refused to pound on one that didn't have a hammer end.
I have pallets to disassemble...
I have nails on said pallets to remove
Ok... this Dewalt Die Grinder is NOT NEW but I loaned it out TWO years ago... when it was new and just got it back.
That might of been me I got a set of those recently and posted pics of them in the new tools section used a bunch of my surprise points got them cheap.
.Yep... I remember the surprise point comment... I also got $15 in points that got used... To be honest... I was sold on buying it with just the ball end... I certainly don't need the torx... it was a bonus. Also missed they were wobbles until I went to place the order. In the end.. I'm happy with them.
If you notice... I have two spots open... I need a 3mm and 4mm for something... I ordered them from Snap On... ...should be here before.
seems like there hangin on like by a thread.
