FMC1959
I just got this grinder
http://www.garagejournal.com/forum/showthread.php?p=6153863&posted=1#post6153863
Below are pics of the wiring, pic # 6 has wire labeling. I have to assume it is currently wired for 240, it has a 20 amp 250v twist lock plug.
There are 6 wires coming out of the motor housing into this box.
#1 goes to the black Marette connector, connects to the red wire and then goes up to the on/off switch box.
#2, #3 and one of the unmarked black wires are connected with the yellow Marette connector and terminate there.
#4 goes to the terminal block and connects to terminal #1
the last wire of the 6, unmarked black wire goes to the capacitor (starter?), and then a wire from there goes to the terminal and attaches to terminal #2
Lastly, from terminal # 3, a wire goes up to the on/off switch box. Not sure of the significance but this wire leaving terminal #3, has a label you can barely see behind the red wire that has a # 3 and as it is halfway up to the on/off swath box it has a label #1.
Home wiring I have no issues but this motor wiring is not my expertise for sure. From checking some online motor diagrams, I think I need to split up wire #2, #3 and black wire in the yellow Marette. Take #3 and the black and connect it to the black Marette with wire #1 and the red wire.
Then take remaining wire #2 and connect it to the wire coming off of terminal #3 and going up to the on/off switch box.
I could be correct or completely off base on this. Anyone have expertise for this kind of wiring?
Thanks
Thanks
