Hagatronics
Hi All
I'm about to do some light fabrication of some steel frames etc (e.g up to 50mm hollow tubing) and want to pick up a few angle grinders. I'd like to have three grinders all-up so I don't have to change disks too often between grinding, cutting and a flap disk. I'll often do other light work (auto body, light fabrication etc) and weld with MIG and TIG.
My question is what size & min power angle grinder would you recommend for these three operations?
On what basis would you buy 4, 4.5 or 5 inch grinders? Is a larger 6-7 inch better for cutting?
I already have a 100mm (4") 500W Ryobi grinder - it's old, cheap, low power and doesn't have a spindle lock but worth keeping in the mix.
I'll probably buy Makita or Metabo but I'm more interested in your views on disc diameter and power for these three tasks.
