Laser Alignment / Line / Level?
ToddW
In the snow
I see these things on amazon from $15 to $800+ :scared:
Just looking to see if anything in the $100 range is worthwhile? I don't mind measuring and doing it 'old school' but wouldn't mind shaving time off the projects ahead.
Most all of the levels I use are Stabila brand but I can't see dropping their asking price or anywhere near it for something I won't use too often.
Other brands or specific models to look at?
Basically just want a laser line on the wall that's level and set at height I 'set' it to make drilling holes good w/out measuring each hole ;)
Empty Pockets
Rural New York
I have had a CM laser level for about 15 years, it has served me well. With the current money problems being experienced by Sears, that would be a consideration before I bought anything there today
T
ToddW
In the snow
I'm rather :mad: at Sears and Craftsmen.
I got some of their pro polished ratchets 2 years ago and was just now able to use them, excitedly grabbed the 1/2" went to use it and it ratcheted once and then locked up :wtf: can't switch lever, can't twist, NOTHING.
I'm debating if it's worth swapping out or just rebuilding it myself :headscrat
guy48065
Calibration Lab
For <$100 you should get one with a floating mechanism that gives you a level line without fussing with leg adjustments & bubble levels like on the cheapest ones. There's no convenience to a laser level if you must first level the level.
T
ToddW
In the snow
Thanks, any suggestions on the 'one' ?
Milton Shaw
Look and see if you can find one of the rotary Dewalt of Bosch lasers used on Ebay. I got a Dewalt for some where around $100, as I remember,it's been 8 years or so ago. Batteries were bad but it takes every Dewalt battery from 9.6 to 18 so I had some others that I could use.
texasfiremedic
Canton. TX
Spend the money on pls and be done. Best there is.
+1
I have a PLS Pacific laser Systems. Expensive but worth the price. For no more than you are wanting to do you can get a smaller hand held unit that is self leveling.
It really boils down to how much you want to spend and what features you want. The features will dictate price.
danski0224
Near Naperville, IL
In some ways, yes. I have yet to find anything, with the possible exception of HILTI, that has lasers that are as bright AND as well focused as PLS products.
But, PLS still continues to omit a pendulum lock on their self-leveling dot and line lasers. I have a PLS 180 that needs to be "serviced" (exchanged at a discount off of retail price) due to no pendulum lock.
danski0224
Near Naperville, IL
You can get Bosch refurbished units at CPO outlet and other locations. This is your $100 playing field.
No one has a brighter and better focused red line or dot than PLS unless you are willing to go to HILTI or other pro-grade tools. The red PLS 180 is a very nice tool.
Bosch is not as bright as PLS, but it is less money.
Newer variations have individual lasers that stick out in a square housing from the top, side and front and project a 360* beam, and these will also give you a square corner. The DeWalt version with the green beam is great... but the lines are not as crisp as a PLS 180 green beam.
T
ToddW
In the snow
For how little this will be used I can't justify going with pro-grade, or really much over $100. I have no problem if it's justified, and the tool will be in use for 10+ years... like my Hilti 14.4V impact driver :) :) love that thing!!
I'll check CPO out thanks danski!
bcradio
New Mexico
If you get a good one, it will be used much more than your stabilas. They are so uselful.
tarbellb
Oregon
Another thread asking similar quesiton: Same answer.
Get a <$100 Bosch or Dewalt 2 LINE laser level. Accurate to 1/8" over 25' I think.
Grab the extension pole for more versatility.
tarbellb
Oregon
DO NOT get the dots. Basically worthless imo.
I have the lesser version of the one posted, simple cross lines. But that 360 model looks nice.
