Laser Parking Guides? Tried it?
thundercow
Austin, TX
Anyone ever tried those laser parking guides? they are sold on eBay and Amazon, you mounted on the ceiling and it's activated when a car comes in the garage, and you pre-set this laser to a spot on your dashboard and that's how you know where to stop. It seems like it could be a pretty good idea, and if it's bright enough to see, I can't see why it wouldn't work. And I have like an epoxy floor, cabinets, and I'm still parking with the tennis ball...
russlaferrera
Central Virginia
I made a suggestion to use one when placing a vehicle on a lift. In this way it would be more centered. Now if I will get to it, I shall report if it was a good/bad suggestion.
dps
They work great, easy to see even in pretty strong light, and you don't have the tennis ball tantalizing the dog all the time.
Jack Olsen
Los Angeles
I bought one. Not very useful, in my opinion. Getting the car positioned right is about as difficult/easy as it ever was. I'd rate it as slightly less useful than the old tennis ball on a string trick.
66HertzClone
Long Valley, NJ
I added them after laying down the RaceDeck tiles. The tiles made it easy for my wife to center her truck, the laser tells her when to stop. She (very important) and I are very happy with them.
ScaldedDog
Sedalia, CO/NSB, FL
x2. Mine are worthless. The trick, I think, is to mount them exactly where the hook would be if you were using a tennis ball, so they point *straight down*. I didn't do this, but I think it would work much better than at an angle.
Wanna buy a couple of them?
Mark
Gary S
Bismarck, ND
I just drive in and shut the engine off. I can't see messing with lasers and such to do something as simple as parking my truck.
sigtauenus
I have the tennis ball for my wife's parking spot. If my wife is off too far to one side the kids will bang the door of her Lexus into the fridge or cabinets, too far over to the other and she or the kids will bang the door into my 68 Mustang.
e-tek
Saskatoon, SK
Totally needed for the wife. If her car is parked right there's lots of room for people and shoes and the dog.....Guys seem to have better depth perception (who said that??!!:wtf:)
nathank
West Texas
There was a set of 2 on Woot the other day for $20, so I thought what the heck. They really are pretty neat, and they work great.
nate379
Palmer, AK
Sounds like some wife's need remedial driver's training!
I always thought those contraptions where when your like 70 years years old and can't tell if you are 10 ft or 10 inches from something!
Chris Adams
They have their uses.
In my rather tight parking garage we use a convex mirror, a laser parking system and a hanging 'tennis' ball. The ball is actually soft rubber, better than a tennis ball, less likely to attract idiots hitting it. A real problem with hanging markers. Almost anybody who comes into the garage wants to bat at it...
Adults more than kids.
Anyway, pros and cons of each system;
On my F150 the laser isn't too useful. There is nothing on the hood, or dash, to help you navigate the red dot. So parking with it is about useless. You would need to have a dot, line, something, on the hood to use as a reference point. If your car slopes away sharply or has no visible configuration on the hood the laser is not going to help.
The Tracker has a light sensor on the dash that is completely visible so you 'aim' the laser dot along the hood till it hits the sensor, then shut it down.
The Touring Coupe has the same problem as the F150.
Tennis ball works perfectly on the F150 as you bump the windshield near the mirror and that means you can drop the door.
Tennis ball doesn't work very well with the Tracker. There isn't enough parallax with the very short vehicle and very steep windshield. You 'hit the ball' rather than sloping up to it. Thus the ball can bounce away from the window, and then you must wait till it settles.
So laser for Tracker, ball for F150 and the mirror helps with the coupe.
Convex mirror works great with the coupe because you can tell the passenger mirror is going to clear. You can't actually SEE the mirror and the spring with the naked eye, so the mirror in the corner of the ceiling lets you tell when you have the one to three inches clearance you need.
On parking, lots of people have very tight garages, and multiple cars. Each car MUST fit in an area about three inches wider than the vehicle. The Tracker must come in with less than one inch distance between the mirror and the garage door springs. Hitting that is a bear without helper items. Also, I need to park each vehicle within one or two inches, MAX of the garage door.
My wife has no depth perception so it is harder for her (never did have it, bad vision in her left eye) but it is still hard to park to within an inch without help.
Also makes it harder if you own/drive LOTS of cars. Only have four right now, well six if you count things to big to park in the garages, but I have owned hundreds of cars/trucks over the years.
A guy who only drives one car and parks in a roomy (defined as more than three INCHES of slop doesn't cause a ding) wouldn't need any of these tricks.
2_lude
TX
I have a pretty tight garage for two cars. Installed 2 of these and adjusted them to point on a specific place on the dash. Perfect parking every time. No need to wedge myself between the tool box and the car. Takes some time to adjust them, but once you do don't need to change it.
If you have a big garage I can probably see no reason for the tennis ball or laser. But if you need to park in a specific place every time it works well.
T
thundercow
Austin, TX
Ha HAAA! It works! Turns on when I open the door, and works in broad daylight...
nissan_crawler
Wichita, KS
I have roughly 2.5" of clearance front and back, and have about 6" of total leeway left to right.
Oh, and it has to be done backing in.
2.5" back, and I just put the drill press table into the tailgate.
2.5" forward, and I just slammed the garage door supports into my front bumper.
3" to the right, and I just hit my engine hoist.
3" to the left, I just hit my engine hoist, table saw, and laundry closet.
I can back a semi up to an auger, but good luck getting this right. Depending on which way I'm off, it will cost me $500-$1500.
Sorry, I'll stick to using my tennis ball. I would love to see somebody pull this off, day in, day out, year round, and never mess up.
Cholleman
I've been thinking about picking up a laser for the wife. too far forward and she either hits my bench or i can't get to anything. too far back and the door will hit the bumper. kind of a pain to have to get out and check your spot, then re-adjust everytime you pull in to park.
z28snksknr
Turnersville, NJ
I'm not trying to be a smartass here, but how hard is it to park a car? I can pull my Camaro into my garage blindfolded and never be off target because I know how big it is. If I'm off by 2", I break off my side mirrors or smash up my front end and the drywall. Never had a problem yet.
There aren't tennis balls and lasers out on the streets or parking lots. How do you judge when there are moving cars surrounding you? I suggest just knowing your car dimensions a little better.
Seems like an excuse to spend money if you ask me. Especially if you already have a system in place (tennis ball). Then again, I don't have "really nice epoxy floor money". If I did, I'd probably indulge a bit more I guess.
plain2car
Gilbert, Arizona
I guess I am a lucky one!! neither I nor my wife use anything but our own ability to park in the garage. She just needs to be on the left side to be able to orientate herself. I then can park on the other side. she is really good about knowing her space area (?) she knows a point on the front end of the armada that she uses to judge her depth. So far so good no ooppss' LOL!!....
eldirector
I use one of these:
images
http://www.brookstone.com/park-it-e...=searchResults|C4CategoryProdList1FDT|7172097
I have a 3/4 crew-cab truck that is within 18" of the depth of the garage. This little thing turns yellow as you approach, and then red at your pre-set distance. Works like a champ, and only needs batteries every 3 years.
Could I park it w/o assistance? Sure. But now the wife, who rarely drives the truck, can pull in without any problem.
s_morrison57
Vancouver BC
I use the old ball trick but mine is a heavy ball, Lacrosse I think and it runs to the ceiling and through a pulley and then to the top of the garage door. When the door is open the ball comes down and when closed the ball is up and outta sight. The door is almost always closed cause I heat in the winter and AC in the summer. You need a heavy ball to keep the string/rope tight, works great and people that don't know its there never see it unless they are a passenger in the car and it sorta plays with there mind when they see the ball going up and down, I painted it to look like a blood shot eye so its sorta like " here's looking right back at ya ", its off set to the right side and I line it up with the passenger side headlight on the 930 so it comes down right in their view.
TonyMazz
Wisconsin
While I live in Wi and last year it reached -34-F and attached garage dipped to 34-degrees... once there...lasers weren't worth a damn.... junked the idea and simply use 2x4's... pull up them until truck tire touchs and I am done. Cheap and moveable...
If I didn't have them, my wife would pull all the way up to my bench...
nissan_crawler
Wichita, KS
Again, try backing a pickup in. Now, you can't see the drill press table behind it, the table saw behind it, or the cherry picker supports that you have to put your hitch between. You also can't tell how far you are from smashing the laundry cabinet.
Now try and do that with 2.5" of leeway on each end, and about 6" left to right. Let me know how it goes.
Yeah, I can pull in a car with a nice low hood and tell where I'm going, duh.
All you people that keep asking this stupid question, obviously haven't been in a tight situation like that.
This is how it used to be, it's worse now. The stuff at the back stick out further now, and the hitch has to go between the cherry picker supports instead of the tablesaw, plus the drill press is back there.
z28snksknr
Turnersville, NJ
Like I said, I wasn't trying to be a smartass. You probably never drove a 4th gen F-body because you're visibility stops at the dashboard, so you don't see where the front of the car is. If you removed everything from the firewall forward, you wouldn't be able to tell from the driver's seat. As a result, I've "learned" the dimensions of the car and can pretty much park it anywhere within 1-2" of the invisible front end. I have a pickup also and after parking the Camaro for 10 years now, the pickup is a breeze (although I don't back it in)
If your garage requires you to back in a pickup truck into a space that is that tight, then buying a parking assistance tool is certainly warranted. Judging by the OP's garage (or at least his avatar), it doesn't appear that he is working with the same limitations you are.
nate379
Palmer, AK
Any reason to just not park outside if your garage parking is so tight?
I have plenty of room in my garage, but I usually park in the driveway.
Git
S Cal
That is exactly like I have mine set up - works great.
Also, I took one of the light bulbs out of the garage door opener and screwed in one of the adapters so that I can plug in the transformer for the laser. Now, the laser will only come on when the garage door light is on, which is usually only for a couple of minutes after the door is opened or closed
nissan_crawler
Wichita, KS
If it's inside I don't have to let it warm up, don't have to scrape windows or brush 6" of snow off of it. Plus, then everything melts and dries overnight, doors don't freeze, etc.
wesalexleft
Memphis, TN
I'm going to give the laser assist a try. I'm parking an XL beast into a garage almost 20X20.
Images of front and back attached after a "guided more, more, more, STOP!"
Schtauffer
Reading, PA
Laser parking assists work great as long as you pull in to the garage to park. They don't work very good if you back in.
abstamaria
Manila
What a relief. I thought I was the only one who couldn't center a car as a matter of course. Reading that post by someone who has a great garage AND races a very fast car makes me feel less incompetent. Thanks, Jack.
I just installed a 2-post lift and found quickly that it wasn't easy getting a car centered between the posts. As an ad hoc remedy, I marked the exact center between the posts with stickers on the floor and try to aim for those. A straight line marking the center all the way to the back end is more useful (I used a steel tape measure fo try this). The problem is that the hood will block the view of the floor. There is also the problem of parallax.
Accordingly, I have been thinking of a laser
guide. I thought that something like my laser string, which paints a long straight line, would be more useful as it will tell me whether I am centered even as I begin to enter the garage. My laser string won't be bright enough with an open garage door.
I have a motley collection of old cars whose widths vary by more than a foot. That compounds the problem. Someone come up with a solution please.
I sympathize with the wives mentioned on this thread.
Andy
atk406
Bismarck, ND
Wow, after seeing some of the spots you guys have to squeeze into, I should really stop complaining about not enough parking room in my garage.
Jack Olsen
Los Angeles
It's funny. At speed, I can place the front wheels of a car very precisely. But when I have to stop and think about it, I'm terrible at knowing where the corners of the car actually are -- and I've got the curb rash to prove it. I think it's the difference from automatic/trained behavior and conscious/deliberate behavior.
Or I'm just very lucky at the track. :)
RVDan
North America
I bought one right after I put my new garage doors on. Then after backing the car in I realized there was nowhere usefull that I could install it on the ceiling, the open garage door covers most of it.
I took it back and stuck a small piece of 2x4 to the floor with silicone.
Yes I can park in a parking lot, yes I can park a 40' motorhome in my shop at work, I can even back up monster size trailers within inches of another one
but my car in my home garage, its a tight fit. I need it in just far enough to be able to get around the front of it to latch the garage door, any further and I can't walk around the back of it to get to the rest of the garage.
HemiRambler
Cleveland, Ohio
I genuinely have no depth perception, so yes it is difficult at times. In my garage it's a little easier because I have learned ways to cheat, but when parking in unfamiliar territory it's quite common to be off in my judgement by a foot or two.
But what I REALLY wanna see is you parking blindfolded - now THAT would be something. But heck I'll settle for you putting a blindfold over one eye. Piece of cake - right?? ;-)
Provincial
Near Salem, OR
We have a very small garage. The door clears the mirrors of my wife's Pilot by about 2.5" if you are centered perfectly. Not too critical front to back. My wife would not try to park the Pilot in there at first. I got the car lined up perfectly and stapled a piece of pink surveyors tape vertically on the back wall in line with the driver's seat/steering wheel. Then I hung a tennis ball on that line where it would touch the windshield at the proper point. After testing it for a month, I replaced the surveyors tape with reflective strip from the side of semi trailers.
To use the system you open the door with the remote, then line up the tennis ball centered on the reflective strip. Then you drive to the strip. If the ball moves off line, you have drifted off and either need to correct or start over.
The important thing in precision parking is to have enough reference points to establish the line you need to follow to your desired location. If you need to stop at a precise point, then you need another reference point/line.
Steevo
43.49600, -112.04300
My wife's spot has a tennis ball, and she still "pushes" it, rather than stopping when it touches the windshield.
My spot for my daily commuter has a super high-tech parking stop, made by duct-taping a piece of 2x3 to the floor.
