what is a good propane mini torch ?
mbshop
visalia ca
I had a nice one loong ago but some one stole it and I just kinda moved on. I bought some cheap refillable unit but it was junk from the gitgo. So now 20 years later I'm finding I need one again. What have you guys found to work well ? I already have a propane torch that uses the canisters. Need a palm sized one. Thanks,
white91formula
Boston, MA
I have a Master MT-76 and it came with the soldering and hot air attachment. Been awesome around the garage. I use it constantly.
mbshop
visalia ca
Thanks, interesting because the junk one I bought was a mt-11. Will have to relook at that brand.
Rubiman14
SE MI
I've been using a Vector torch for a few years and love it. It was an Xmas gift from a coworker. Until reading this I never looked them up...wow they're expensive!
FigureItOut
Bentonville AR
What are you doing with it? The Portasol kball linked is very nice. It's rebranded on the SO truck also. Caveat though, it's really set up for soldering. It has other attachments but I haven't found them particularly effective.
Portasol does have a couple more general purpose torches, I think they range from $40-$100. You can bet that just about anything you get from them will be high quality. They're made in Ireland, and are also rebranded as Weller.
mbshop
visalia ca
I have a bernzomatic soldering torch so I'm covered in that aspect. Just seem to keep reaching for a handy little torch that isn't there. The one from hf looks like the old one I had that was stolen. I'll look into the others mentioned. Thanks,
theoldwizard1
SE MI
Most of the small handheld torches are actually butane.
Most of the various different brands are just re-branded Portasol torches.
PBCampbell
WV
Bernzomatic used to have a torch handle/hose setup for use with the disposable cylinders that was pretty small. The only other option would be one of the high end air/fuel torch handles with the smallest tube/tip size or an oxy/fuel setup like a Smith. I kind of think the OP meant butane too though.
rshadd
Doylestown, PA
I've had my blazer for 5 years and it still works great.
mbshop
visalia ca
My bad, ment butane. Already have a propane torch. And yes, the blazer shown above is what I had and need. Thanks,
cliftonbros89
Missouri
I just bought a Power Probe butane torch. Haven't got a chance to use it yet though. Got it for small things. Like heat shrink for wiring and battery cables. I'm sure it'll be handy for several other things.
engineer2
Chicago burbs
Avoid the Master Appliance MT-11 or variants thereof. A pain to use and unreliable. You better have a strong thumb to hold the trigger valve down. Mine's going out in the next garage sale.
MoonRise
For heat shrink tubing, I have found a 'mini' hot air gun to be awesome.
Try a craft/art store for one. One of the better $10-$15 (IIRC, it's been a few years since I bought the thing) or so things I've bought. No flame, just a controllable relatively gentle hot air flow. And that air flow seems to 'wrap around' the heat shrink tubing and get the heat around the tubing a bit better than a flame does.
If it died today, I'd pick up a replacement one today or tomorrow at the latest.
Just an FYI. :thumbup:
cliftonbros89
Missouri
Yeah. A heat gun. I know what you're talking about. Like a hair dryer on steroids. If I were to get one I'd need a cordless one.
mbshop
visalia ca
Well, threw up my hands and got the hf one. So far it works fine and is what I need for the little use it will get. Once I'm convinced it will last a bit I will take the safety off as its a pain and only I will be using it.
mbshop
visalia ca
Well dismantling the trigger safety is not as easy as one would think. So after looking at it for a while I saw that the part that resets or releases the lock back into place has a small tab. If the tab is gone then the safety will not reset. Hopefully.
mbshop
visalia ca
Well, my first try was a total disaster. Basically time spent with no results. While messing around, one old tired brain cell up and slapped me and pointed to the obvious simple solution. So I heated up a small screwdriver and while holding the safety down I melted part of the channel its in over thus blocking the safety from moving back up and blocking the button. Now I can push the button all I want at anytime without having to deal with the safety. Not for everyone but its a fix I needed. Thanks for listening.
Infinia
SoCal
Should of bought the one from my link but then you'd hafta wait a little longer for gratification,
FigureItOut
Bentonville AR
Hey Milwaukee R&D, did you hear that? We need a cordless heat gun, like yesterday....
Actually I'd rather see it in Bosch 12V, but they'd keep it in Europe like some of their other cool stuff and I'd have to fly there. I hate long flights.
mbshop
visalia ca
Well, just not sure that would have worked for me. The hf one has already payed off in melting plastic so I could weld two pieces together.
mbshop
visalia ca
just to finish this off, I have to say the one I bought has more than lived up to my expectations. it just plain works. no muss, no fuss. that is all.
Finky198
North East
I use a Benzomatic TS8000 with propane on up to 5/8" ish hardware and it'll work just fine. Ive added a hose so I can get it into tighter places then the oxy/act setup. They both work with some cross over it just takes a bit longer. Our oxy set up is pretty large so I try to avoid rolling it out unless I need some serious heat or am bending or cutting stuff in the shop.
