Syberia
EDIT: Photobucket ****** my images. Here's the imgur version: https://imgur.com/a/TysSx
Finally have the money (and time) to start a project that the wife and I have been talking about for a while - building our own teardrop trailer. Like some of the other examples online, we started with the 4x8 flatbed trailer from Harbor Freight and will be building everything else on top of it. We hope to at least have the basic structure done by the end of the month, so we can take it camping with her parents.
Here's what we started with, the 1720 lb utility trailer from Harbor Freight. Made a couple of modifications to it right off the bat; installed a trailer jack on the tongue (not visible in this picture) and changed over to a 7-pin connector and wiring harness (as well as running all wires through plastic flexible tubing and wrapping with electrical tape) so that our truck will recharge the trailer battery while towing it.
Attached a grid of 2x3s to the outer frame and each of the metal slats going across (don't seem to have a good pic of this, but I used carriage bolts through the unused holes that were already in the frame) and screwed down a piece of plywood.
Painted the bottom with roofing tar to seal out water
And attached panels of foam insulation to keep the cold out.
No insulation over the axle because that's where the water tank is going. A 34-gallon 42" x 20.5" x 11" tank just fits in that space.
I glued on a 1/8" sheet of birch plywood just to cover up the screw holes and bolt holes through the main decking.
I haven't installed them yet (hope to get to it tonight) but I cut out the shape of the trailer from 2 sheets of 1/2" plywood (outer walls) and 2 sheets of 1/4" plywood (inside walls). They will be separated by 1.5" of foam insulation.
