New work light suggestions
Shane8820
Well, it's that time again, looking for a new work light. I'm looking for something around the $100 range or less that is super bright but will also get in tight spaces. It needs to be adjustable and magnetic. If it has a hanging hook awesome. The brighter the better. Something along the lines of the Snap On ECFHKY. I'm looking for compact and bright. IMG_0912.JPG
6PTsocket
High tech is great but an old 60 watt incandescent is 800 lumens. The 13 watt fluoresent drop lights are about the same. The 26 watt fluorescents have two 13 watt bulbs for twice that. I don't want to give up light to get LEDs even if the are cordless. The latest generation of LEDs called COB, chip on board. produce more light for less current and can get a lot of light in a cordless drop light. That is what I would be looking at. There is also the matter of color temperature. Personally, I can't stand the very blue daylight bulbs but to each his own.
DHCrocks
Hawaii
yes, the Bosch FL12 is great. its small, has a bright flood pattern, has a magnet and hook, ratcheting position. lasts me about 4-5 hours on high. I got 3 of them. its good to have multiples so you can position them at different angles to eliminate shadows and dark spots. if your're in the Bosch 12V max line these are a must have. even if you're not these are really good and versatile lights.
johninct
Buy the Snap-On. I have one and use it all of the time. I can get it in a small cramped area. For me it works out great!! The magnet and bracket I feel are just as important to making the light great as the light itself. My only complaint is that they put a piece of tape over the magnet to protect it and it isn't the best, so I just put a piece of masking tape over it and change it when dirty. Santa is bringing me another one for Christmas!!!!
Shane8820
I don't mind paying that kind of price, I just want a good bright compact magnetic light.
brianmc02
Another vote for the Bosch FL12. Very bright and even light pattern. I have two and expect to get more.
Brian McCarthy
DHCrocks
Hawaii
I just used them this past weekend to do my brakes. Here you can see how small the Bosch FL12 is. I have two of them using the hooks to hang off of the spring and the magnet was at just the right position to stick to the spring also to prevent movement. The ratcheting head was then positioned to aim the light at my work area. The two lights at different heights gave good spread without shadows. By not having to use a corded light really makes things easier.
Markfothebeast
I like those Ebay 5050 LED light strips. Not cordless, but cheap, mountable, and include a remote control. Could run off DC if the power supply was modified.
Sent from my SM-G920V using Tapatalk
Danglerb
SoCal
I just bought one of the new Larry COB LED lights off ebay for $6.25 shipped, 170 Lumens and runs on 2x or 3x AAA, I forget which. I prefer to use two or three of this type of light, so I can move one around to get something specific lit, but not reduce the overall lighted area. Adding a headlight to the mix helps too.
Shane8820
I don't have anything Bosch so I wouldn't think that would be the most economical option.
kctyphoon
Jersey/Staten Island
Does Milwaukee make an M12 light similar to that Bosch?
Not being rude, but u can just go on the Milwaukee site and look at every light they make in less time then ud wait for an answer.
But yes Milwaukee makes an m12 stick like that gets alot of love on here..
A cheaper option is the Neiko or Capri tool led light that I actually like better. It's $30 on Amazon right now
bcradio
New Mexico
might have to get me one of them Bosch 12v lights with all the good reviews here. Have lots of Bosch batteries I do not use since switching to Milwaukee.
cliftonbros89
Missouri
Olafur
Iceland
^^^this. My Matco guy showed me a Matco branded one. I intend to pick one up after the new year. Magnetic holds really well. Plus you can adjust how bright it is. It gets bright! Looked like a really awesome light. Plus it has a pretty thin profile.
I have used one - "Förch" brand.
Great light with bad battery life, and then you have to use USB to charge it that takes forever.
Don't bother!
Olafur
Iceland
I want to propose an alternative.
Good work light:
Is not to bright because if so it will create shadows and glares and is simply not comfortable -irritating and your eyes have to constantly adjust to it. Yes, bright light is fine for one hour job once in a while, but for 8-10 hour days - it gets old very quickly.
Has good even flood to illuminate the work area without hot-spots or dark areas.
Last but not least it should light up the work area from the right angle and leave your hands free to do the work. Most of the time the only light that fits the bill is a good headlamp.
I never cared for headlamps until I met this one, after I got it I discovered what was wrong with the headlamps I had already tried (uneven light, to bright, to dim, junk straps, battery hogs etc).;
4 years and counting: check!
Over 2000 hours runtime: check!
Fallen on concrete floor many times: check!
Been outside in rain and snow many times: check!
Covered (literally) in oil few times: check!
Fantastic even flood light for close up work: check!
No-nonsense on and off with gloves: check!
Strap still comfortable after several trips to the washing machine: check!
Runs for approx 20 hours on 2 AA NiMH batteries on lowest setting. And the lowest setting is what I use 90% of the time because it's just right for most close up work situations. And it has very good flood and decent throw on higher settings.
It dims down and gives you a warning when batteries run down - you still have hours of usable light before it turns off. Needless to say I have two pairs of batteries so I never have to wait for recharge.
Honestly - after I got this light I feel sorry for my co-workers who are constantly buying new lights and haven't embraced the fantastic usability of a good professional headlight. None of the stuff they have bought for the past 4 years comes close to a good headlamp in usability - this one does it all!
Downside - some girls find it a bit bulky and heavy.
There are others out there, Zebralight comes to mind but I have never tried one.
Danglerb
SoCal
Got my ebay $6.25 Larry COB today in the mail, noticeably brighter than my original Larry, very smooth flood, same basic light as original Larry. Shipping was fast so I may gift a few.
Looking at some recent tear downs in the flash light forums I am holding off on a more expensive light as they have LOTS of room for improvement in both packaging and performance.
thegroundpounder99
Balm Fl
Nebo Cryket light has a swivel head on it and it has a beam and flood option.
They also have a rechargeable Work Bright 2 but it comes with hanger, magnet and swivels. Little longer then the Snap On light but also has a flashlight on top.
Shane8820
Good work light:
I have a zebralight and it's awesome. I wouldn't trade it for anything. I lost one once and soon as I figured out that it was gone, I ordered a new one without a second thought. I use mine on medium most of the time but oh high it taps out at 1000 lumens. The problem I face is I need a supplemental type light and that's why I've asked about a compact light.
Olafur
Iceland
In that case I would take a look at the slim cob light posted above. I have used it once during difficult task where obstructions blocked my headlight. I liked it for what it was. However the owner of said light informs me he is not happy with it because of short battery life and long recharge time. Since you already have good headlamp this is probably not much of an issue for supplementary light. In your neck of the woods the price seems reasonable too. Over here not so much.
:beer:
