10" Bench Grinder Wheels
FMC1959
Montreal, Canada / Upstate NY
Two questions:
First, anyone with a bench grinder, regardless of the size, do you prefer a grinding stone on each side, or a stone and wire wheel on the other?
Second, anyone with a 10" bench grinder, where are you finding stones, wire wheels...etc?
I ended up getting a grinding stone and a wire wheel at Lehigh Valley Abrasives. They had 2 stone wheels and 1 wire wheel to choose from in 10". It's pretty much like that every place I check, either nothing or very little to choose from. About the only places I did not check were Grainger and MSC, because their pricing is so ridiculous
EBay may have had the most choice, but even they have the same items repeated over and over, just different vendor.
pstemari
Seattle
I have a medium and a fine wheel on my 8" grinder. The white Norton wheels work a lot better when grinding hss or cobalt tool bits for the lathe.
Sent from my Nexus 6 using Tapatalk
GTO
NJ,FL
I have an 8" bench grinder,I have a stone on one side and a wire wheel on the other.
6PTsocket
Two questions:
There are a lot of 10" grinding wheels on eBay.
blazemaster83
Lacey, Wa.
Ebay or mcmaster would be my choice. I have a grinding wheel on one side, heavy duty wire wheel on the other. Try finding a good selection of 14" grinding and wire wheels.....cheap.
F
FMC1959
I agree, but now as much as you see at first glance. Then you see many are cut-off wheels, many repeat the same wheel but different vendor, some either the price or the shipping makes for a $200+ wheel, in short, there is more choice, but still limited.
F
FMC1959
Like I mentioned in a previous post, I new finding 10" wheels would be more difficult. That said, I have a general purpose, medium/coarse wheel & a medium wire wheel on order. I should be good with this combo, maybe down the road I might get a fine stone.
For me a grinder is not something I often change wheels for different job. I was just asking to see if someone had found a place that had decent quality stones, a good variety without breaking the bank.
EOC_Jason
Bentonville, AR
McMaster, eBay, or Amazon is where I typically look.
I have an old CMan block grinder that uses 7"... So yeah it's a bit of an oddball.
On my old 8" 3/4 HP Dayton I have a stone on the left (80 I think) and a wire wheel on the right. It's setup this way for sharpening lawn mower blades, but I also do chisels and occasionally large drill bits.
On my 7" 1/2 HP Craftsman I currently have two different buffing wheels.
I kind of want a 3rd bench grinder, actually I want a 1725 RPM for buffing... If I had that then I would use the Craftsman with a wire wheel and a white norton wheel, like 100-120 grit. Then the Dayton I would have the two original stones on (60 & 80 I think they are).
I also have a couple unitized deburring wheels, and some clean 'n strip or whatever wheels. The deburring wheel is like a solid scotch-brite, great for polishing and removing sharp edges. The clean n strip is good for taking rust off, it's also like a big scotch brite pad but chunkier...
I don't like changing wheels because I take the time to shim / balance them, and once I have them running true and smooth I want to leave them alone. Hence the multiple bench grinders.
Sorry for getting a little off topic...
What's the cost for a 10" wire wheel? If it's too much I would just slap in an 8" and be happy with that. You can get some good old USA made ones on eBay.
I wish I could afford a real brass wire wheel (not the brass coated steel wheels).
notlob
norcal
Zoro carries quite a few 10" grinding and wire wheels:
https://www.zoro.com/search?q=10%22+grinding+wheel
2oolhound
BC Canada
First Q
I prefer just grinding stones on my 10" for heavy grinding. A twisted wire wheel on the 8" is adequate for removing powder coat and rust off metal in prep for welding. 50% of all bench grinder use is on the 10" coarse. 25% is on the 8" wire wheel. The other 25% is split among the other grinders.
Not counting an older 8" 3/4hp unit, this is what I'm using now:
> 10" 1HP has a fine and a coarse wheel. I mostly go through coarse wheels. When they wear down to 7" or so I profile them as round for notching pipe or similar profiles on specific work pieces.
> 8" 3/4 HP with wire wheel and denim buffer wheel which is almost rock hard. I also made a contraption to mount a drill bit guide onto it for sharpening drill bits with a stone wheel but not currently on this grinder.
> 8" Buffer 1hp.
> 6" 1/2HP grinder with coarse wheel and wire wheel
> 6" 1/3 HP (but it's a balder so different league from other HP ratings) with green stone and coarse stone mounted on the lathe frame for sharpening tool bits.
Second Q
I've always picked up stones at swap meets or CL (just like my grinders) so haven't had to buy new yet although I'm on my last 10" coarse now and may have to break down and order a couple new ones soon. Otherwise I have a decent selection of stones and wire wheels under 10".
454ragtop
Carver, MA
There is no problem finding 10" wheels, plenty around, but not for $10. A 10" grinder is more industrial than home owner, which is a good thing, but wheels will always be more expensive. Best bet is Ebay, will take some time to sort thru, but there are always bargains to be had. They turn up at swap meets and flea markets on occasion as well, but not nearly as often as the smaller sizes.
F
FMC1959
Good stuff Jason, look for a 10" or larger, it will most likely be 1700 rpm.
F
FMC1959
First Q
> 8" Buffer 1hp.
Second Q
Next summer I'll definitely be checking the flea markets.
6PTsocket
I see you also have my old Cman grinder. If you are planning to buff, buy a buffer instead of trying to adapt a grinder. The wheels are nice and far from the motor, no guards to remove. I just bought a 2 speed buffer but haven't used it yet. The low speed should be safer for plastic.
EOC_Jason
Bentonville, AR
All depends on what I can find. I only paid $20 for that CMan at an estate sale. :) The Dayton I got off eBay, it was brand new still in original box and packaging. (Notice the plate showing made in 1987? LOL)... Cost almost as much to ship as I paid for it, but it is heavy duty and serious torque.
6PTsocket
That works. If the price is right it is a GREAT buffer.
2oolhound
BC Canada
I did a ton of serious buffing with my 8" 3/4hp grinder. Then I scored a proper buffer. That 8" was also my main grinder till I scored the 10". Sometimes you gotta make do and work up when opportunity knocks.
EOC_Jason
Bentonville, AR
Speaking of... So I was at an estate sale today. Digging around a corner under a bunch of stuff I find this old little homemade buffer setup... Can't complain for $4. :)
Ignore the other things in the pic, that's just what else I got.. lol.
1725 RPM, very quiet... Needs a little rewiring, but can't complain. I just polish small stuff so this will work perfect.
