Re: The Lone Beech Garage Build Thread (60x46)
JB,
I, like you, suspect this problem may have existed for a while. I'm fairly sure it is only leaking when the dispenser is actually dispensing water. Not using the dispenser (sign on the fridge) and I intend to pull the fridge out from the wall and face the situation after Christmas.
Best regards,
Scott
You will get to the festoon cable soon enough and will not think about how long it took to get to it. As for the fridge leak, I had water pooling on the floor 8' from the fridge, turns out there was a very small pin hole in the plastic line going to the fridge. This meant the water had been leaking for a long time and ruined the drywall and molding. All in all the fix for the leak was a couple dollars but lots of repair work for such a simple problem. Hopefully it isn't too major for you.
JB
JB,
Best regards,
Scott
