Modifications to the HF 4 and 5 drawer service carts - what changes have you made?
Stknuckl
yes to all
Thank you. how where the Castors added if the side drawers aren't as tall as the roll cart so that the Castors are on the floor and it's not Teeter tottering? I'm sure some kind of shims or spacers right? Any pictures i maybe haven't came across yet so maybe I can get an idea. Any help is appreciated.
stonesg
SE Georgia
I am also happy i finally removed the lid of the tool cart. It always collected parts that would then block access to tools. Having my go to wrenches and screwdrivers always accessible and visible has been very useful.
This is why I didn't even buy this cart. I liked it a lot but I know how I work so I went to Northern and got their $99 dollar cart that has a sliding top vs. one that flips up. This way I still have a horizontal surface but have access to the tools.
http://www.northerntool.com/shop/tools/product_200657585_200657585
I like the mods here and I'm going to incorporate a few of them on my cart, like the additional drawers in the bottom.
I bring this up as this could be an option for others as it was for me.
WWheeler
Middleofnowhere USA
Here's a post from a month or two back that might give you some idea ...
In a way yes, you can just hook it to the side but it tips easy. 893702817de0f4db26435c9cb20cdd35.jpg
This is a better way to do it
Snakebyt
Lubbock Tx
has anyone fitted one of the red side table to the black service cart? my bluepoint cart has a side table and i wanted to add another, but for $160, ill pass, so i want to put one or possibly 2 of them to my black service cart
555
Nomad-Arkansas & Georgia
Not a black service cart, but I added one of the HF side tables to my black Waterloo rolling cabinet. I intended to paint the side table black, but it was cold and raining. Now I doubt I will paint it. I kind of like the red/black combo. Here's a picture.
ihateminimumwage
Get the Sunex black side shelf. I Installed it on mine when I had it.
http://www.garagejournal.com/forum/showpost.php?p=2843055&postcount=308
555
was it hard to make it fit your cart? i assume i will need to drill some mounting holes or something
I drilled four holes in the cabinet and mounted it with 1/4 x 20 bolts/nuts. Two of the side table holes were perfect, but two of them would have hit a drawer slide. I drill new holes in the side table bracket at a place where there was no interference with the cabinet. It was not difficult and although I did it by myself, it would be easier with two people. One holds it in place, the other drills and then bolts. I used one of the 18" Harbor Freight magnet strips to hold it in place while I marked my holes and again when I was putting the bolts/nuts in place.
Mrmontebuilder
Got my Snap On hinges yesterday finally and put them on last night. Having the lid tilt back slightly is much better than stock with the struts in my opinion. Only issue I have is I have a total of 7 of the HF magnetic strips on the lid holding a total of 32 ratchet wrenches and 12 stubby non ratchet wrenches and the right hinge hits the wrenches when you close the lid. Will have to rearrange things a bit but it should all work out.
DanInVA
Last weekend I Kaizen foamed my 5 drawer service cart. My speed improved dramatically from the top shelf to the last drawer. The fastcap kaizen foam hot knife made finishing out the drawers and small adjustments to get the tools to fit better much easier.
That looks really great. I really like the clean, organized look that you get with the foam.
Sent from my SM-G920V using Tapatalk
Stknuckl
Anyone have problems with the 26 inch cart not being strong enough to hold your additional side boxes with tools? Maybe you had to beef up the bottom where the casters go to stiffen it up and make it stronger?
mbshop
visalia ca
I would tend to stay away from exceeding the design parameters of tools such as doing that. Otherwise you would need to at least build a new frame to carry the weight as some have done.
gmillz
Does anybody here have the 5 drawer with HF pneumatic wheels on it?
Sent from my XT1575 using Tapatalk
cheechi
Triad, NC
someone did that way earlier in this thread, you'll have to dig a while. prob between pages 30-90 if that helps.
WWheeler
Middleofnowhere USA
I've not used them on my HF cart, but I've got a flat cart with a small 5 drawer tool chest on it that in the past 7-8 years I've gone though two sets of HF 8" pneumatic casters, and I'm needing to replace them again really bad.
Both times I bought them because they were on sale cheaper than I could find similar anywhere else, but both times within 2 years they started leaking down and before 3 years they all go flat within days. Right now they are all flat and if/when I need to move it I'll have to air them up which won't hold for a day if I'm lucky. I tried slime in them but they seem to leak between the rim and the tire. Didn't help. I hate them. I hate myself for buying a second set of them expecting a different result.
toyodajeff
Has anybody ever broke the drawer locks on there red cart? Will harbor freight replace them or sell replacement locks? Just wondering before I buy the 56 inch box. I'm talking about the plastic push button things you use to open each individual drawer. The 42 inch box doesn't have them it has the detents.
Tucker99
Elkton, Maryland
Assuming you mean drawer latches? I took mine off. Put them in a ziplock back and duck-taped them under the box. Don't know why, was thinking if I sold the cart the new owner would want them. Yea, there is a detent for the drawers but it is very "mild".
toyodajeff
Yea the latches I like them, just wondering how well they hold up or if they are replacable before I buy the 56er
RAYJAY
UNION DALE PA
I have one of the red 5 drawers at work, since they first came out,
The latches are holding up really great, as is the box.
however the locks on these boxes really ****......
must of been thru 4 to 5 replacements from HF they just wear out
Westozfixer
Western Australia
Ive got 2 of them now, I'll have to check my new one. In its defence my first one has a GP master set sitting up high under the lid and you sort of have to pull it down a bit for it to latch.
Slowcorrado
Figured I had to throw a message in here to register my surprise at how nice the black cart is. I built one my brother got for Christmas today and the quality was amazing for the price!
Left all fasteners loose until the end, no issues.
Would love to see a picture of how the lock interfaces with the lid. The lock "arm" was bent at a really weird angle and I straightened it thinking it was damaged. WRONG. They must be bent from the factory. Now I can't get it to latch properly.
Exceller8
Banning, CA
I've been working on some mods for my cart. I'll post a finished picture when I'm done. I did add this metal peg board today which I think looks pretty cool and it will allow me even more tool storage.
PelicanPines
In case anyone is interested, this is where I got the red peg board. I didn't have to cut anything, it was sized just perfect for the cart. The best part is you get two of them for $35, enough to do both sides if you wanted.
https://www.amazon.com/dp/B001J7GKE8/?tag=atomicindus08-20
My cart is modified to fit my needs well. DAMN, I wish I saw this option to cover the side... If you go back and look at my mods... one of the things that I disliked about the carts is the unfinished sides that showed the rivets for the drawer slides. I covered mine up with sheet metal painted to match the cart.
I would have much rather had your option.
Exceller8
Banning, CA
That's too bad... What page is your cart pictures on?
