Are Proto J288 and Blue Point PWC80A cutters the same?
5spdfrk
I'm looking for a good wire/cable cutter for 1/0 gauge marine cable and the Blue Point PWC80A cutters were recommended to me. I'm only able to find them direct through SnapOn though. In my search for them, I came across the Proto J288 cutters, which appear to be identical for almost half the price.
I don't mind paying for quality, however, I don't want to overpay for it either. Does anyone know if the Protos are simply rebranded Blue Points?
Thanks in advance!
lilcraigford
Portland, ME
Imperial is the OE of the Proto/Blue Point cutters (someone correct me if I am wrong). In case you prefer different color or name on the handles, here is a list of other brands that carry that style cutter: :D
Armstrong 67-850
Blue Point PWC80A
Cornwell STBC3
Matco BCC3
Imperial BS-103
Proto J288
SK 15032
...I need to do an info dump in the "The Truck Tool Equivalents" thread at some point.
Derek420
Southern Indiana
I wouldn't suggest those for cutting steel cable as they are for copper, I would suggest into looking at Klein's heavy duty ratchets cutters or one of the other heavy duty cutters.
5spdfrk
Armstrong 67-850
Blue Point PWC80A
Cornwell STBC3
Matco BCC3
Imperial BS-103
Proto J288
SK 15032
You are the man! Looks like the Imperial and SK cutters have added cushion in the grip, I might end up going for one of those.
No worries, I'm cutting battery cable/wires.
What diameter are you cutting up to?
Max will be 1/0 marine wire.
