MATCO/bonney goodness
K
krusty the clown
Member Emeritus
niangua, mo
I have an older 14mm like those. I am intrigued now, how do you like them?
they are well liked by the members here........i found that while searching for a few sizes i need but i don't need the whole set. someone here NEEDS to buy them so i don't!
K
krusty the clown
Member Emeritus
niangua, mo
snap on owns the right's to the bonney name. i believe it was bought specifiaclly for the torque adapters.
merk you would have a winner with that idea, the open end spread was the only weak point of the bonney combo's.
wrenchr
I prefer the V design and I know it might be weaker but it sure does look good!! And I have never spread one either.
sk farmer
nd
sweet wrenches. i have the 3/8 to 3/4 and they are hands down my favorites. i own snap-on craftsman thorsen and mac knucklesaver in that similar length and that is about the order of preferance also. in some instances the cman are even out front of the snap-on. it helps that the cman are the old sk made pros. someone here had the sizes to fill in up to 1 1/4 a while back and i passed. i most likely should not have.
Bull
I did not know that the older Matcos were made by Bonney. I want to pick up a set of SAE and a set of metric Bonneys...this lets me expand my search.
Are there any stampings or marks on the Matcos so I can be sure I am getting the Bonney version?
Also, for the Bonneys themselves, which version of their wrench has this super-comfortable beam that Merk and others talk about? I have seen a couple different types of Bonney wrench, and not all of them seem to have thick beams.
K
krusty the clown
Member Emeritus
niangua, mo
these are the bonney made matco's............
they were numbered WCLxxx
they were discontinued in 97 and replaced with the RCL and then the MCL series.
Bull
So, any and all Matcos that have the code WCL... will be from Bonney?
K
krusty the clown
Member Emeritus
niangua, mo
correct.......in the early day's matco also sold unpolished square beam wrenches labled WH series. they are a dead ringer for MAC's but not polished. knowing the connection between the two companies i'd bet they were sourced from MAC.
joenero
north ca
So the RCL wrenches with the bonney style open end are actually not bonney? I liked the later styles because the chrome was better but if I don't have a real bonney then.....
MAD
Western MA
Here is a short 10mm I have had since the mid 1980s.
K
krusty the clown
Member Emeritus
niangua, mo
i believe the RCL's were armstrong's.......when they changed to the arch open end thay became MCL's
K
krusty the clown
Member Emeritus
niangua, mo
my fault.......let me explain the numbering system.
W=wrench
C=combination
L=long
the WC and WCL's were both bonney made, just long and short.
MAD's wrench is a WC10M2 so.....wrench, combination, 10M (millimeter), 2 (12 pt).
a six point would be WC10M6
Paumanok
LI,NY
Krusty, thanks for the heads up on these:bowdown::thumbup: I've been wanting some nice Bonneys for a while, can't wait to get them:bounce:
Bull
Ok, great info.
Now, might I ask about the "scalloped" Bonneys? Are they anywhere near as comfortable as the version we have been discussing here? I'm now referring to the ones that look like this:
Bull
Ok, I picked up a set of Bonney flare nut wrenches a couple months back. Are the good Bonney combo wrenches like this, in terms of beam shape/thickness? Or, are they different still?
Bull
I wish that the AA website showed more beam views...they only have one for the polished Bonneys. What I don't get, is that from above, the beam really does not look that thick. :headscrat
