The VISES of Garage Journal
SteveL
St. Louis, MO
Tried to pull the slide all the way out but ran in to major resistance once the lead screw finally ran out. Not wanting to mess something up, I stopped. Any suggestions to persuade it out? Is there a pin or something underneath that I need to access?
454ragtop
Carver, MA
Probably the slide has a burr or is distorted from using it as an anvil. Inspect closely, and carefully clean it up with a fine file as needed.
mike_paxton
Steve:
I normally try cleaning the slides and then open up the lead screw until it is completely out of the main nut. Takes a little wiggle of slide once out, to get it to slide apart.
Once you have access to inside, you will see the pin hole inside above the main nut. It's always easier to take main nut out by extracting the pin that holds it in place. However, if the main nut won't easily come out, I leave it in place and work around it.
If I had the tools, I'd do it like Topop101 suggested in post #2914 at following link. http://www.garagejournal.com/forum/showthread.php?t=252830&page=146
However, if I didn't have Topop101 tools, I'd do like CwazyWabbit suggested in post #2917 and use a bridge clamp, a large ratchet socket, a punch and a cheater bar on the bridge clamp handle to try and pop pin up from bottom.
Don't get frustrated, as it can take some time before it finally pops out.
Mike
macgee
Sepulveda Pass, CA
Mac: take pictures even if you don't buy everything if you have time. good luck and thanks for the well wishes.
Well, it was an interesting pick. No one else was there so had a private pick, the gentleman was very nice but a wall in the garage caught fire and everything had black soot on it.
The vise I wanted he decided to keep as his bigger one walked away last week but I was able to get a Palmgren angle vise and a 6" Heinrich speed vise (have no need for them) along with a bunch of other stuff (30 new usa made end mills & slit slit cutters).
I'm wondering which model that Craftsman is? It looked like a 4" jaw, it was really the only thing I wanted other than the end mills, it was in really nice condition. $20 bucks for everything so I'm not complaining.
macgee
Sepulveda Pass, CA
Mac, if it is the 4", it's a 5183 with the swivel base option. About 1960.
Thanks Outlaw,
Correct me if I'm wrong but I think it maybe a #506 because the swivel base is round unlike the 5183's square shaped swivel base? These seem to fetch a lot less than the 5183. I still may have a chance to grab it if I trade him for another vise.
I didn't notice those two items, but you are right, However the screw head is not correct; but there have been other instances where the flattened head was not in synch - From my notes:
the flat-nose style Reed with the adjustable front collar. - Patent applied for in Jan. 1936, granted in Aug. 1938. 2127008
bluebolt
Benton LA
That's why I think it is 1938-1939, the patent shows a round nose screw, not a flat nose. The Craftsman Reed's made around 1945 have a round nose. I have seen a few other "R" Reeds with the ball nose.
SteveL
St. Louis, MO
Thanks guys, there were a couple of spots were someone had use it as an anvil and bulged the top edges a little. Small file cleaned them up nicely and the slide came right out. Will work on getting the pin out tomorrow.
Would be cool if t is around a '39 as that's the same as my Delta Unisaw and 6" jointer.
Mohawk Dave
SoCal
Picked up another 6" today. In good shape as well.
Chas Parker 436. 187lbs.
My first Parker, and it's a Humpback!
va.grouseman
Southern-Central VA.
Mohawk, there was one on EBay a couple weeks ago that nice, they were asking $1200.00 for it.---There is another on there now, not quite as good for $599.00 but you have to pick it up.---They're not cheap and that one you got is a really nice one.---Most of the time they are pretty beat up.
Shiftless
East Bay SFO
macgee:
Still a great score! :beer:
Mohawk:
Might as well start at the top. That is a monster. My 6 inch Parker was way too big for my bench so I 3-way traded it for a baby bullet.
Mohawk Dave
SoCal
macgee:
Mohawk:
Thanks. Quite a bit smaller than my Athol 8", and I think smaller than my American Scale 6" Swivel Jaw....
But, dang, humpbacks are cool looking! :thumbup:
trijeff
Northern Cali
MD: re: the 107 ... love love love Reeds. Was hoping this was a 108 when I saw the ad, turned out to be the 107. Posted it here, Brad (demoman) is the one who probably convinced me most I should go get it. Wish it was four hole base and replaceable jaws, but apparently a pretty rare bird so you get what you get, right? ;) Like you, also have bigger, but this is my first 7". Need to replace the handle (or at least a ball end) and static rear and slide were used for anviling a bit (lots of dings, but relatively light), still overall pretty good shape. Jaws are the factory flat type, still plenty of original hatching. In the process of moving, will be a bit before I post more pics and restore. Probably end up moving this one along, but that's what I think about all the Reeds I have picked up and I still have them allm :)
4Nines
You did good trijeff! I think the Reed 107s are more rare than the 108s. I need to get my 107 cleaned up and on a good stand soon.
drivesitfar
TJ: when you get some daylight and some time can you take some more pictures and post them up? you know that's why we wanted you buy it, but for the price you bought it for isn't it better than having some cash in your bank account? LIFT WITH YOUR LEGS!! and good luck with your move.
ALL: traffic and too much eating took away from my vise shopping stop so i'll just have to get organized and see if maybe i can find something i've already bought that i forgot about and make it my last find of 2016.
cheers
bluebolt
Benton LA
It's definitely right there around 1939. It has to be at least August 1938 with the patent number on there. I looked at some other bulb nose "R" Reed's and they were all Patent Pending so far.
rusty65
Pekin,IL
Picked up the bigger brother to my little salesman sample it has 2 3/4in jaws and out of curiosity does anyone know of they made a smaller one then 2 3/4in jaw?
Sent from my XT1585 using Tapatalk
wrenchguy
NW Indiana
My Reed 207 2nd from left, between the 8" Morgan and 7" Yost far left. Its a heavy swiveler in real good shape. Its got 08, 12, 14 patent dates. What does the brochures say it weighs? thanks 4 any help.
cajunfirehawk
Ms Gulf Coast
Brorex
Hey guys just wondering if someone can tell me where to get jaw screws for a craftsman 5160. Pics of screw attached. Not sure if screws like this have a name or they're just made like that for this vise. I had to drill them out pulling the jaws and while they work the way they are I'd like to get new ones if at all possible. I'm contemplating trying to turn some down on the lathe but if I could purchase would probably be better quality. Thanks
Sent from my SAMSUNG-SM-N920A using Tapatalk
