RXtacy's small detached rotary haven
Xander
I'm as bright as I look in the picture above.
Lifts sure are handy. To answer your question I am looking at a scissor lift, otherwise I might do a 4 post and not use it to the full height potential. I didn't like the 2 post setup, both for getting on in just the right spot to get the pads under the right part of each specific car, and then where the doors line up with the posts. A few inches left or right could make getting in either a breeze, or a real PITA
I good friend just bought a 4 post, and it would work well in my single garage, the only down side is that i probably won't be able to drop the engine out of my 911. (Still have to check on that)
X...
R
RXtacy
Rockville, MD
what lifts are those? do they go up together at the same time?
They are made by Dayang. Yes they are hydraulically synced so they go up together.
X...
Gotcha. 4 posts are nice if you need to store vehicles, but they would not be my preferred choice for a service lift. They also take up a LOT of room.
R
RXtacy
Rockville, MD
Starting to get my tools moved into the garage, and putting it to use.
R
RXtacy
Rockville, MD
Hope everyone had a good Christmas!
I was able to make some progress on the driveway gate in between family obligations.
The added benefit of these lifts is that they make great work platforms. They can also double as in/out feed tables!
LoRollinLS
Garage has come along nicely! I can't help but see your Everlast welder back there, what kind is it? I've been contemplating buying an Everlast tig/plasma combo. I would like to know how you like yours?
R
RXtacy
Rockville, MD
It's an Everlast PowerPro 256S which is a TIG/Plasma/Stick combo. I've had it for over 3 years now and while it doesn't get constant use I use it pretty regularly. I have to say I've been quite happy with it. Has more than enough power to do everything I could ever need and has nice features (AC/DC TIG, Pulse, 2T/4T control, AC frequency adjustment etc). It's by no means as polished (packaging/adjustments wise) as the big names, but it is very hard to beat for the price. I had a foot pedal **** out in the first year and Everlast shipped a new one under warranty no problem. I would definitely look into them.
R
RXtacy
Rockville, MD
First gate frame is all welded up and ready for paint and then wood pickets. The house side post is painted and ready to install. Need to finish welding the second frame and far side post.
HemiRamOn22s
Delaware
Rain barrels! Do you plan on reusing the water? Looks like the lifts are getting put to good use already! Just be careful welding on the epoxy. Welding/grinding sparks will pit it.
R
RXtacy
Rockville, MD
The rain barrels were a requirement by the county for runoff control, they were not my choice.
For clarification the floor coating is Rust Bullet not an epoxy, but you are still correct weld/plasma slag will burn it. TIG welding and cutting/grinding doesn't seem to bother it though thankfully.
HemiRamOn22s
Delaware
Nice! Is there a boiler drain on the bottom so you can attach a garden hose?
I was leaning towards RB myself if i dont use Racedeck on the house garage. Im just concerned with Hot Tire Lift. I guess time will tell this summer with your garage.
rmorse
Oh my god....I just found this thread! I'm pretty sure I've seen your rx7 at Katie's C&C too. I have a yellow T5R wagon that I take there every now and then.
But anyway, I live in Beltsville. Can we please be best friends.
M-technik-3
Western Mass
Rain Barrels are smart idea, free water when it comes to springtime. Watering garden and lawn vs using drinking water. If you have town water you would pay for sewer and water as it is dependent on the meter going into the house.
Needless to say we had a very tough drought here in the Northeast this past summer. I have a bunch of them and in my town their were ten new wells drilled because folks went dry. We had some water issues as well.
Looks great, do you have a link the the lifts? I'm curious about em but I already bought a two post from Greg Smith inc.
R
RXtacy
Rockville, MD
Yes there are, I haven't installed the valves on most of the barrels yet.
I liked the idea of no etching and "less prep", but honestly the whole process probably took as long as prep/epoxy would have with cure times between coats. Not sure what I would go with next time.
I have "garage" tiles in my basement shop. The dark ones show dirt very easily which would be a concern for me in the garage.
:lol:
I've actually never been to Katie's. I've been meaning to as I see a lot of amazing cars come out.
I have some fond memories in my buddies Volvo brick from high school. Unfortunately it wasn't a T5R.
I work in Greenbelt so pass by Beltsville every day. I get all my metal stock from the Metal Supermarket in Beltsville :thumbup:
I like the idea of free water, but honestly I find the rain barrels incredibly hideous. I would honestly rather not have them, but it is what it is.
I've had one on the front of the house, it doesn't have enough pressure to really flow through a hose. What are you guys using to water your lawns off a rain barrel? Is there an easy in line pump?
You can read to your hearts content about the lifts in this thread.
http://www.garagejournal.com/forum/showthread.php?t=35433
I got mine from Dyang.
http://www.dy-autoequip.com/html/2014/carlifts_0724/34.html
Greg Smith also sells a virtually identical unit.
http://www.gregsmithequipment.com/FM9SL-In-Ground-Lift
LoRollinLS
Thanks for the great feedback! I will definitely be considering this soon. Do you have a MIG setup as well or do you use the Everlast for everything?
Threadkiller
Dutchess County, NY
RX great thread! Your garage looks awesome. Couple questions for you. Where did you get that scissor lift? A quick google search didn't come up with anything. That looks like once of the nicest flush mount scissor lifts I've seen. Also would you mind me asking if you had a roundabout price for the building and construction? Like you, I've also been dreaming about a detached garage with a lift and I'm just trying to figure out rough costs so I could plan accordingly. Thanks and enjoy your awesome new space.
R
RXtacy
Rockville, MD
I don't currently have a MIG. Almost got a Miller 211 last time they were on clearance with the Miller rebate, but didn't jump. It definitely would have made the gate project quicker, but more TIG practice is never a bad thing :lol:
Thank you. If you look two posts up (post 137) it has info on the lifts. Mine are from a company in China called Dayang. I dealt directly with Renny from Dayang [email protected]
madoc1
spicewood, tx
looking better all the time. i like the idea of using the lift as a work surface. rain water collection is pretty common here in central texas. especially for domestic use. you can check out morio's build. he has no town water or well. if he ever ran low, he could get water from night train, another member. he started a business filling peoples tanks. and yes, it is also good for the yard and garden! :D
jim
R
RXtacy
Rockville, MD
Update:
Got the retaining wall done, and started wiring up the wall lights. Just need to finish the conduit into the garage to finalize the wiring.
I also get one side of the driveway get finished and installed. Forgot to grab a picture of that, but here is the gate before install.
R
RXtacy
Rockville, MD
It's been a while, been doing a lot of traveling for work so never have as much time in the shop as I would like. Finally got my driveway gate up and running.
Still need to tidy up the conduit and primary gate wiring, but she's working like a champ!
Here are two videos of it in action.
cros13
Sydney, Australia
Great build, just read it from the beginning.
I really like how the floor came out, and i like the look of the garage in general. Looking forward to more updates!
Chem1
RXtacy,
Could you tell me how far back from the back wall you placed your lifts? I think I remember reading somewhere you wanted enough room for cabinets along the wall.
Did that distance end up working out well for you?
Thanks!
Hawk136439
Illinois
Subscribed! I would love some more information on that gate when you get a chance, dealing with a similar house/driveway/garage setup.
R
RXtacy
Rockville, MD
Thank you.
RXtacy,
Thanks!
They are ~158" from the back wall to the center of the lift if I remember correctly. I do plan to move my workbenches along the back wall. I like the distance so far. It puts the cars pretty close to the door but still leaves enough room to walk behind when on the lift.
Sure, what would you like to know?
I used 4x4x.25 square tube for the posts with .25" thick plates for the bearing supports. House side the post is anchored in the concrete with 6 5/16" SS concrete anchors. Far side post is sunk ~36" in the ground and concreted in place.
Gate frames are 1x1 tube with angle iron on the top and bottom that I through drilled to secure the wood pickets. There is also a 1x1 cross member in the middle that the operators attach to.
The gates swing on 3/4" mounted bearings top and bottom. They swing SUPER easy with very little resistance (before I installed the operators the wind would blow them around A LOT).
I ran conduit under the driveway before we poured. One conduit from the house with a 120V outlet and a separate conduit from one side of the driveway to the other for the control wiring for the second operator.
That's most of the details I can think of off the top of my head, but let me know if you have any other questions.
Gentleman Adventurer
Mother Rucker, The Heart of Dixie
RXtacy;
Nice clean shop! Just read through the process.
A couple more questions about your gates:
What bearings did you use? Got a link? I'm assuming they are designed for outdoor use.
Is that a 12' wide gate? Very clean look. I need to do something similar in a 12 to 14 foot width. For a 14' gate, if I put an angle brace from the top of the bearing side to the center opening on each gate, do you think that would be enough support? Or do you thing the gate tubing should be upsized? What about the 4x4 uprights? 5x5s maybe?
Thanks for the help.
Keith
R
RXtacy
Rockville, MD
RXtacy;
Keith
Thank you.
I used standard 3/4" mounted bearings. You can get them just about anywhere (Amazon, Northern Tool, McMaster Carr, Grainger, etc).
My gate spans just over 14' including the posts. The posts are incredibly stable, I would not expect you would need to up-size them. If you prefer the look of larger posts aesthetically you could go larger, but structurally they should not be needed.
The gate frame tubing is really a function of how sturdy/heavy you want the gates to be. Mine are plenty sturdy for my application, but have some flex in them if you were to apply a significant load at the unsupported end. If you want them to be stiffer you could increase the frame member sizes or add some additional bracing members.
R
RXtacy
Rockville, MD
Had my first "major" maintenance project in the garage this weekend doing the clutch on my RX-8. The lifts worked out awesome!
RXTacy;
Thanks for the size information. I just want 14' between the open gates, so that should be a minor increase in spacing. I think the material you used will be fine. i currently have a wooden fence (hate wood fences) with a 10' double gate supported by 6x6 posts with a light metal frame reinforcement. It sags. I need to enlarge it a bit to get an RV behind it. No heavy load on the unsupported ends, unless some one climbs it. Guess that would be vandalism then.:D
On another note: It looks like you built some pit covers. Don't hold out on us, what did you do?:rocker:
R
RXtacy
Rockville, MD
RXTacy;
Agreed, you should be in good shape.
Not sure what you're referring to, but I haven't built anything to cover the lift pits :dunno:
To be honest haven't really felt the need.
R
RXtacy
Rockville, MD
Quick update of where the garage is currently. Been slowly moving things over as I need them. Got my blast cabinet, belt sander, work benches, tool boxes, and bench grinder moved over. The shop is still pretty messy. I need to get the drywall up so I can put my cabinets up and get some of the clutter cleared up.
RX;
After looking at the picture again, it was an optical illusion. The front wall of the pit looked like it was horizontal and covering the opening. I thought you had made some removable covers so the jacks wouldn't accidentally fall in the opening. Sorry for the confusion.
