Cleaning old steel tools
Dlarry
Wisconsin
I recently came across old rusty indrusto tools that I have started cleaning. I'm waiting because after scrubbing the rust I noticed the finished product appears to be a brass colored. I'm not sure if I am scrubbing too hard or if the is another factor. I used a pre-soak solution of and salt which soaked for 24 hours and then scrubbed the rust with a brass- bristle brush.
Does anyone know if i damaged the tool, or if there is a better way to clean the rest of the tools?
*the tools that I am curious about are the hammer and the large wrench.
tym
The softer brass is transferring to the tool, imparting the color.
I've used a vinegar soak overnight and judicious use of a stainless steel brush with small-diameter bristles.
D
Dlarry
Wisconsin
Thanks guys! I just tried a stainless steel brush on another wrench with much better results.
As a follow up, any recommendations on removing the now brass colored wrench?
Mintgrun
Kingston, Wa.
You could just leave it that way.
Eventually it will wear off.
After a lot of use, my electrolysis set up started depositing a thin copper layer onto the pieces I was taking the rust off of. It came from the wire I'd used to dangle the parts. I was upset at first and a little confused. The new solution does not do it.
I like coming across those copper tinted wrenches, when digging through my box : )
Tomthumb717
Hanover, PA
I second the above in regards to evaporust I use it on any smaller items or pieces with hard to reach areas. Let it soak for overnight or for a day and any rust will turn to a black film that can be easily removed.
isb cornbinder
I bought an ultrasonic parts 30 litre parts cleaner from DURASONIX in Langley, BC. Their brand is Durasonix. These parts cleaners work really well. I use a little Simple Green to make the water wetter. These cleaners have heaters.
This is my second parts cleaner from them. The last one was 6.5 litre and I sold it to a friend.
Your American dollar buys $1.38 in Canada. Durasonix ships.
I think salt may be a really bad idea. Salt destroys car bodies made of steel, so salt may contribute to rusting on your tools.
6PTsocket
What would happen if you hung a piece of clean steel and reversed the electrodes. Wouldn't the brass plate off the wrench and onto the other piece? It worked for copper. Brass is copper and tin.
6PTsocket
I am somewhat confused what does the salt do in the overall process??? I also thought (key word) that any use of salt was a not good for any metal.
Does evaporust contain any salt?
http://www.evapo-rust.com/product-info/
I believe the salt makes the electrolyte more conductive. I think it is salt plus air exposure thst does the damage. You want to rinse it off as soon as it comes out of the tank.
crerus75
I can tell you from experience that if you use a muriatic acid solution to clean enough copper fittings, it will eventually plate your vintage Williams DOE S-wrenches with a shiny layer of copper when all you REALLY wanted was to remove a couple decades of rust. It will also eat craters in a cheap zinc wrench that you thought was steel. Wish I had pics, but I don't even know where those wrenches are right now.
isb cornbinder
I have had great success with cleaning old paint and dried grease with a product we call GUN WASH.
Gun Wash is the harsh solvent painters use to clean paint guns and other tools of that trade. I bought a big aluminum cooking pot and lid at a restaurant supply. I put about 20 litres of gun wash in the pot then a powder coated wheel. In about 8 hours the powder coat is soft enough to remove with a pressure washer. I would not recommend using a flammable solvent in an ultrasonic parts cleaner.
