Sticks McGee
My 2 cents:
You seem very similar to me in your projects you have done, projects you have planned and the tools you have available
My tools:
Grizzly 1023 (older) table saw
Dewalt router in a home made router table
Dewalt plunge router
Dewalt random orbit sander
Hitachi 12" sliding miter saw
Dewalt biscuit joiner
Old jig just like the Kreg pocket jig.
About 8 pipe clamps with various pipe lengths
4 12" jorgensen light duty clamps
2 36" jorgensen light duty clamps
4 12" clamps similar to jorgensen that are HF
handful of c clamps and some spring clamps
50" clamp-on cutting guide
Makita Jig saw
Old seras circular saw
Old Skil circular saw (not worm)
18ga brad nailer (HF my brother gave me)
33 gal sears oiless compressor
Sears table top drill press.
I don;t have any of this stuff really organized at the moment but I think this is the #1 thing on my list. Get it organized and in a way that makes it more useable. I waste so much damn time looking for things that should be readily available to use.
Plans I have:
Build a work bnech with storage above and below to mount my vise on and put my drill press on. This will be attached to the wall. I want to build a version of the Paulk work bench that I can use as a main layout and assembly bench. I want to take my table saw and build a mobile cabinet base for it and turn one extension wing into a router table. My current router table is huge (3'x5' with a home made 2x4 base) and I need to save space. This will allow me to utilze the table saw fence for the router. I want to build a miter saw station on wheels for my miter saw. I plan to build one very similar to a Norm Abram one that I saw. Most of my stock is gonna be 8' or less so I don't need a huge miter station to hold 12 and 16 ft pieces. I want storage in the miter station to keep things handy for the miter saw. I want storage in the table saw base to keep all the table saw stuff withn reach as well as the router stuff. I plan to build all of these things to the same height so they can double as extension table for the table saw and temporary additional glue up/assembly surface.
I am perfectly happy using factory sheet goods at this time. Somewhere down the road maybe a jointer, planer and band saw but not really on my short list at this time. The last couple small projects I did I used the biscuit jointer and really liked using it. It in no way will create joints like a tradiaonal mortise and tenon joint but it does make quick, strong and easy to set up joints. I need my stuff to be mobile within the garage but I won't be loading it up and taking it to a jobsite. When not in use I want the stuff to take a much smaller footprint. My garage is 24x24.
Working smarter and more efficiently is on my short list along with picking up more clamps and some better clamps (like the Bessey) My table saw is the center of my most used tools. I use it for ripping, some crosscutting, cutting dados, rabbits and beveling edges. Some of these things can be done with a router too as it does a better job but there are many ways to skin a cat. One of my most recent tool buys is a true stacked head dado to replace the old dual "wobble" blade I had used prior.
My tools:
Makita Jig saw
Plans I have:
