Ok here's my dilemma I have a 3 story 30 x 45 garage and the second floor has PEX in the floor radiant heat tube installed but no heat source for the tubing as of yet. I have no natural gas in my area so my options are propane and electric.
Below are the specs of the garage:
Outside walls are 10" thick cement block with a 6" air gap and then R21 fiberglass insulation. The walls themselves are 1/2" plywood all the way around the building. The inner walls are all R15 fiberglass insulation. The ceiling is 1/2" hard board insulation with R30 blown in insulation above that.
The PEX tubing is stapled directly to the floor with a reflective barrier below it with R21 fiberglass insulation below that in the ceiling of the first floor. The ceiling height is only 6' 6" high not the standard 8'.
The second floor is set up into 4 separate zones.
Zone one is roughly 400 square feet and would need to be heated to normal room temperature.
Zone two is roughly 300 square feet and would need to be heated to 77-79 degrees.
Zone three is roughly 200 square feet and would need to be heated to 72-75 degrees.
Zone 4 is roughly 75 square feet with a 5' 5" ceiling height (yes it's really low) and needs to be heated to 86-89 degrees.
I'm located NE PA so winter here can be pretty brutal. The current overnight is about 10 degrees.
I also need potable hot water for a bathroom sink, and a wash basin for cleaning things. The potable water will not be used too much.
What I need help with is figuring out what type of unit to heat the hot water. I've been told an electric hot water heater in a closed loop system would be best by one local plumber and an electric boiler in the same set up by another. Yet another plumber suggested a propane boiler with an electric on demand hot water system for the potable hot water. I'm so confused and have no clue what to do. Any help would be great. If you need more info please let me know. Thanks Tom
