Hi Guys,
I have a huge favor to ask. Those of you who own this particular lift, can you please measure/check the following for me:
* Are the columns 5"x5"?
* Is the distance between columns 99 1/4" (or 89 1/4" if its the shorter version)?
* What is the size of the base plate?
* Is the space between the column and the edge of the base plate are 2.5" on the sides and 5" in front? Is the back completely flush or is there an extra space?
* What's the height and width of the piece that sits between the column and the base platform. This is the L shaped piece.
* Is the column height 88" flush? Are there any bolts or anything else sticking from the top of the columns?
I am asking these simply because I have a unique situation where my ceilings are very low and the way my garage is, there is barely 1" of clearance between the posts and the garage door tracks. I was going to go with Bendpak's dimensions that they display on their site, but looking at the pictures online, I noticed that the back of the column isnt flush with the baseplate whereas on their website, it looks even. That's worrying me, because if the distance between the two posts (inner distance) is actually less than 99 1/2", this wont fit.
I called bendpak and the response I got was "sales people only know what's on those sheets, they dont want us in the warehouse opening the packages". They also said the numbers are "approximate" which is worrying.
One other question I had was, just to confirm my math is correct, the minimum ceiling height to lift the posts is calculated as = the length of the post (88") ^ 2 + width of the longest section of the baseplate (10") ^ 2 = x ^ 2 and solve for x gives you 88.56". My ceiling is only 90". I am guessing this will fit barely? I am also assuming the crossbars between columns can be inserted while both posts are on the ground (rather than using a forklift like the manual states) and you can just lift both columns together?
Lastly, I am not going to bolt the unit down, is that okay?
I appreciate your help
