I'm trying to figure out a rational way to electrify a 36 x 34 addition to my studio. It's built out of structural insulated panels -- they come with drywall attached. The inside is taped and primed. It's just a big open space -- 12' walls/ cathedral ceiling. The lighting is currently powered from the main building .. I use a heavy extension cord from the main building if I need to use a powered tool.
Originally, was thinking EMT was my only solution - that requires laying out the outlets .. both for 220v tools and the normal 120v. Was thinking I could have some drops and tee off with a plug strip on each side of a surface box -- does anyone know how code looks at the plug strips? I was able to get 12 of the 6' strips (each has 5 double outlets). They are Hubbell Plugtrak. Got them cheap -- not worried if it does not work.
I was further thinking I could place a 220v outlet in each of the drop boxes. Example: Three drops down the wall to a surface box holding a 220v outlet -- tee off on each side with the 6' Plugtrak. That gives me the whole 36' wall space covered with outlets and three 220v outlets spaced out on the wall. Not sure how many circuits code is going to force me to use.
Was at a friends house last summer -- his concrete outbuilding was wired (inspected) with EMT drops on the wall -- they just used regular romex along the ceiling into the EMT drop to the surface box. He had a bunch of power strips to increase his outlets .. think the raceway is better.
