Anything against code here?
BellyUpFish
Alabama
Thinking about throwing these strips as backers to stabilize the outlet.
Any issues code wise?
No sure why the pic is crooked..
matt_i
SE Michigan
Does the wooden strip have a screw going from inside the box->out to plywood to attach the backup strip?
If so there's a metallic object penetrating the box which is no longer insulated from the plastic. I don't think that is specifically addressed in the code, but I would try to glue it up with construction adhesive or separate fasteners that are nowhere near the j-box.
checkthisout
If you're covering it with osb it will be fine without the backer. Your cover plate will pull it forward and keep it under tension.
Use the metal cover plates instead of plastic.
alfredeneuman
Fullerton, CA
If you're covering it with OSB be aware that the box itself must be flush with or project past any flammable surface. (In case of any sparking)
An alternative is to use plastic or metal "goof rings" that wrap around the devices.
bjcouche
I think I spot the code violation.
There is nothing wrong with the piece of wood behind the box and nailed to the OSB external to the box. I rather like that idea, the cover plate is supposed to be decorative not structural.
What I do see wrong is that he didn't use TR (Tamper Resistant) outlets. Depending on which code revision you are on, you might have to use them everywhere without exception. The latest revision does make a couple exceptions like outlets that are installed behind and blocked by large appliances. The exceptions are very few though.
Realistically, the only place where you are allowed to use non TR outlets are in industrial applications and in replacement of existing non TR outlets in older homes. New construction residential is basically all TR. I don't think they should even carry the non TR outlets in the big box stores. It gives people the false impression that they are actually allowed to use them.
Brian
kwb
PNW
...I don't think they should even carry the non TR outlets in the big box stores. It gives people the false impression that they are actually allowed to use them.
Brian
TR outlets are a PITA and as long as I have a stock of old outlets I will not be installing one.
kwb
PNW
I am just a simple homeowner why would an inspection be going on?
CJ7VFR
Central New Jersey
Why would a simply homeowner keep a "stock of outlets"? You made it seem like you had cases of them.
It does sound like the doesn't it.
I bet he probably means he has a few of the regular/non TR receptacles on hand. I know I do. I keep my "stock of outlets", or usually about three of them, in a box in my basement, along with a variety of different colored switches and cover plates, for repairs or additions around the house.
I like to keep a few of these things on hand because my house was built in 1955, and although the previous original owners did do some upgrades over the years, there are times when a receptacle or switch needs to be replaced because they are becoming faulty.
Since most of my receptacles and switches are white or "cream" colored, I like being able to just go down into the basement, grab what I need, and make a repair on the spot. Then if my small supply runs low, I buy a few more when I go to HD or Lowes.
Jim
