600SL
Hopefully tomorrow I will be brazing in my new heat pump.
My question is can I purge by passing Nitrogen from the condenser high side through the expansion valve and back through the low side line or the reverse. Another words will the expansion valve be open and allow this to happen. If not what should I do when I get to the last fitting. I can regulate with either flow or pressure. What are the recommended flow or pressure ranges. Also first time using an acetylene torch in many years what should I set the pressure to.
Any other tips would also be appreciated.
I will be using a Harris air acetylene torch with Stay-Silv 15 0.050 x 1/8" no flux. Line set is 3/8" and 1 1/8". Torch tips will be #11 and #3
