Usage for small sockets?
muskaman67
I was just wondering, do any of you guys actually ever use your very tiny sockets? like 4mm to 6mm? i have been wrenching for some years and have never come across these sizes. not even a 7mm. Do you think it would be wise of me to have them in my tool box beings that i work at toyota. Thanks!
mrshaun
Killeen - Fort Hood
5.5 on a few electronics and 5mm as well.... but 4 I am not sure.
1/8 and 5/32 if you were working on an apache or a blackhawk helicopter ....
MotoDave
Ventura, CA
The day after you take them out is the day you'll need them :)
I have come across some small sized in electronic equipment and inside laptops, but I prefer the feel of a nut driver that size.
norry
Out of my mind... Be back soon!
I remember being at pick-n-pull a few years back and finding an Olds 98 just like the one we had at the time, except that theirs (somehow!) had an immaculate leather steering wheel in the right color, and ours was all ratty.
I couldn't salvage it because I didn't have the right socket for the trim on the wheel, and the yard was something like a 100 mile round trip from my house. I went through my little 40-in-1 set (you know those...) on our own car once I got home, and the right answer seemed to be some weird fractional size, very small.
Merkava_4
Clovis, CA.
I use the 7mm for the harness that plugs into the car's computer. I have to disconnect the computer and take it out of the car whenever I want to wash the engine.
olds88
New York, NY
Ford COP coils comes to mind, 7mm, and alot of the bolts under the dash on Fords are 7mm. I think some GM under dash stuff is 5.5mm.
TheToolMan
N.J.
I use my small sockets more than the large ones. But i repair electronics and industrial motors
apong23
Los Angeles
Those small metric sizes are also used on the hex posts that hold the motherboard to your computer chasis.
justinmc
KCMO
I find quite a few uses for the sub 10mm stuff in interiors and under dashes on Nissans and other imports. As mentioned alot of ECU harness connector screws are held in by 7mm bolts and same with the brackets that hold the ECU's into place. Seems like I usually reach for mine in a deep variety though even if I could use a short version simply because of not having to grind my hand up against adjacent panels, components, etc. Really just depends on clearance though.
Certainly not worth skipping if you are putting together a good set of tools though. Might not reach for them much.. but generally they are cheaper and when you need them... well you need em!
Fedwrench
Valley of the sun
I thought Toyotas never broke down, why do you need tools? :lol: The only thing I ever used 4mm on was adjusting headlights on a Crown Vic. However 5.5mm is real common on GM AC actuators and other interior trim and controls. Ford also likes the 5.5mm. If you don't like metric sockets, 7/32 is close to 5.5mm. 7mm is the GM trim retainer size of choice along with many bolts on upper engine control components. :beer:
MadMark
New York City
Fenderwell liners and splash shields. Ford uses 5.5mm GM uses 7mm, and Chrysler uses 7mm or 6mm.
Exactly, GM used a 7mm self tapping hex screw to attach fenderwell liners and a lot of trim panels and other stuff in the interior, I actually bought several craftsman 7mm nut drivers for this stuff.
A lot of the gages are held to the dashboard with 5.5mm screws, you can use a 7/32 socket for 5.5 mm
A 9/32 works for 7mm also
