Heating a bolt with Oxy Acetylene torch
jacked_72
I don't have a huge need for heating bolts as I'm no longer in the rust belt, but which kind of tip should I be using when I do? I think my current tip is a #2. Should I go up to a #4 or #6 for the heating?
Bondo
Greenfield, Maine
Ayuh,.... That depends on how big or small the bolt is, 'n what it's stuck in,....
A 1/4" bolt in a small aluminum castin', I might use a #1 tip,....
A 3/4" bolt in a massive iron castin', I'd use my big ole heat bud,....
rlitman
Long Island
Let's start by asking what brand and type of torch you are using. A Victor #2 is nothing at all like a Smith #2 tip, and a cutting tip is nothing like a welding/brazing tip.
J
jacked_72
Uniweld, so same as Victor. I'm not talking about the cutting head tip, but I suppose that can be used for heating a bolt too.
marinusdees
Edgewood, Washington
A rosebud is generally the go-to for mass heating. That said, I'm too lazy to change out the cutting tip I leave in my torch, so I use that instead. Less heat, but much more focused and easier to control. But, cutting tips serve the same purpose, size as said above, dependent on size of area/mass to be heated. Don't be afraid to experiment/play with your torch. Start out small and go big. Or??
bubinga
That's all I've ever used (to heat) all my life working in shops.
A cutting tip is nothing more than a miniature rosebud with an extra hold in the middle.
Thanks, Good to know.
Strouty
Southern Maine
The only times I swap to anything other than the cutting tip is when the hardware is either really small or in a really tight place, the other time is when I have to heat a really large item or large area.
