Max Usable Distance for MHF Wire
anuccite
Richlands, NC
Sparky's:
for 90amp at Garage, What is the Max distance I can go before I need to go to a larger wire (because of voltage drop)? I'm trying to figure out how far away I can put New garage
2-2-2-4 Alu MHF
dw1
Ky
Sparky's:
2-2-2-4 Alu MHF
Do you have any idea about where you want it? how big is your back yard?
Your # 2 alum MHF is rated for 75 amps at 100', not sure if you are talking about lengths longer than that or not?
90 amp load would require 1/0 alum at a max of 190'
A
anuccite
Richlands, NC
So I'm looking at right around 125'. As with most I doubt I will need the 90amps, but will breaker it that way in the house.... and 100 at garage.
buried in conduit
Aceman
Eastern Oregon
125' is not an issue.
Real world experience tells me I don't even start worrying about voltage drop on 240 volt feeders until I get out past 200'.
dw1
Ky
Where are you getting that info from. #2 Al can be over current protected up to 90A. There is no footage rating.
I had plugged the info into the Southwire Voltage drop Calculator, using a 3% VD, I didn't know if he has a 1/4 acre back yard or a 14 acre backyard, I didn't want him trying to run across the globe and expect no consequences from it. I agree he can protect it at 90 amps.
wyliesdiesels
Modesto, CA
The southwire calculator uses 60* c ampacities for circuits less than 100a.
Thats how u got the 75'.
That calculator is a little annoying in that regard. I suspect they do it on purpose.
Better to use a different calculator.
dw1
Ky
Ahhh, my mistake, wasn't paying attention, thanks!!
sberry
Brethren, Michigan
I have used a couple different sized breakers. Ran a welding shop from one at 225 ft one winter with a 60A on it. I have wired a couple dozen garages this way including a couple busy ones and while we could make a change if we had to never,,,, never had one trip a 60, have never tripped a feed breaker on anything I ever fed with these and have several myself including my house on a 50.
A
anuccite
Richlands, NC
I want to be clear on something, In trying to source wire locally, HD, Lowes so far..... Both keep giving me URD wire..... I can't find MHF wire.....
I am assuming that if I want to have a single continuous run, that is not going to work, correct? I cannot run URD inside either structure even if in Conduit?
I can order it from wireandcableyourway.com no problem,
dtrojcak
Lowe's has MHF, but I only looked for 4/0 as that's what I needed.
Most MHs have more than 90 amp service so you may have a time trying to find it in smaller sizes.
nh_yota
Seacoast New Hampshire
Many places use the terms MHF/URD/USE to refer to the same thing. URD technically is only used outside by utility companies because it is not rated for use in NEC installations. USE is an NEC-rated version of URD. MHF is essentially USE that has a 4th conductor and is rated for burial.
wyliesdiesels
Modesto, CA
Order from online site such as this one
or try local electrical distributor.
pattenp
Virginia - USA
You're close but no prize. URD (Underground Residential Distribution) is a type of wire and carries in most cases only a USE insulation rating, hence why it can't be installed inside. MHF (Mobile Home Feeder) type carries insulation ratings of RHH-RHW-USE, so it can also be installed inside along with being direct bury. URD and MHF are not insulation ratings.
