Ign
I have a '99 Dodge ram with rear drums that don't even have ports on the backing plates to adjust the star wheels. There is the outline for the oval shaped place where it should be, but there is no opening. I have had the drums off several times and they haven't hung on the shoes yet, but I'm sure it will happen some day. That's the day I'll be using the above method.
Ironically yes, I was just working on a customer's '99 Ram with the same deal. I started to try to knock out the plugs as they're clearly just tack welded in there but those tacks are no joke and I could see it was going to deform the backing plate if I applied more force. I was just putting it back together actually and just wanted to be able to adjust beginning shoe location from the backside, but it wasn't critical and I needed to just get the truck back on the road so I left the welded plugs.
If it were my truck though I'd take a grinder and remove the metal inserts.
Incidentally she brought it to me 'cause the right rear wheel cylinder was DUMPING FLUID. I went ahead and replaced the left too (you're supposed to - SOP) and good thing I did - when I pulled the actuators out of the left side wheel cylinder it also dumped a bunch of fluid but wasn't yet noticeably leaking visually. 138k miles.
