I used a street 90 with a long ****** and a small 1/4" quarter turn shut off valve. I used brass. No rust or rot.
Remove the drain valve, install a street ell, a piece of pipe long enough to get the valve to where it is easy to reach, and then a ball valve.
After using a drain that discharged on the floor, which stained the floor, an automatic drain that discharges outside was fitted.
2 air diffusers are used as silencers.
This is how I have had mine in my old shop for the past 25+ years. Looking to do a little more refined method in my new shop.
^^Sweet idea. This may be worth stealing for my new shop.
Mike.
zmotor - Thanks. I wish I could find where I bought that auto drain. I have it set to drain on start up and every 10 mins of operation.I also Used an Auto Drain setup and ran it Outside.
But...No silencers.
It comes out the side wall and 90's down toward the ground.
(Probable scares the **** out of the stray Cats running around at night)
I guess they are really called 'mufflers', at least that's how they're listed at McMaster-Carr.Educate me on those air diffusers/silencers please.
That's a good idea.I extended the standard drain and installed a 1/4 turn ball valve but also raised my compressor up about 3" on wooden pucks so I could place a low flat bowl under the valve to catch the water rather than stain the floor. ....
When you guys turn the pipe back up from down low, you are essentially creating a "P" trap for the water to pool in the pipe. Also, if the pipe goes up higher than the bottom of the compressor, it may keep the water in the compressor tank more than having everything level with or below the 90* fitting on the bottom of the tank.
I'm going to have to spend some money now. Where did you get the stainless hardware and cost?
Thanks,
Jeff
I got the stainless from my local industrial hardware store here in Vegas. McFadden Dale. Like a McMaster Carr except local. I don't think it was much more than $50 or so total.
