AMP Clamp for Automotive?
SuzukiGS750EZ
Hey guys. What are some good amp clamps (the type that plug into your DMM, not the individual tester) are good for automotive that aren't a ton of money? I don't use one much but i'd like to have one on hand.
Bill Ramsey
Tulsa
I've been pleased with my Fluke 337. It's discontinued, but that means it'll be reasonably priced if you come across one (paid $69 for mine). It's a complete multi-meter unit with a display, not just a unit that plugs into a multi-meter.
Mark in Indiana
Southern Indiana
I've been using an Amprobe ac-dc 400 for several years. I used to use it for troubleshooting battery powered forklifts and arial lifts.
6PTsocket
I just did a lot of internet searching and they do exist, both a AC and AC/DC. They all seem to be Fuke, not very common, and far more expensive than buying an AC/DC clamp with built in meter, which may or may not have other multimeter functions. The cost of manufacture is in the clamp.Meters are cheap. It is less akward to use and not significantly more expensive to include the meter. No hanging wires to deal with either.
Two Speed
Ontario Canada
Those of you with the amp clamps, what is the low end of their reading ability? I'm more interested in under 10 amp resolution than I would be in 400 amp capabilities.
Alex.
FigureItOut
Bentonville AR
Alex.
I've done parasitic draw testing with this cheapy and found it to be within a useful accuracy range as compared to my Fluke connected in series, down to the 20-30 mA range. I haven't tested it below that, but I suspect that's the lower limit of it's useful range. d306dc4578699e5736ea9c9bed96e736.jpg
Htruck
As a very happy owner of a Fluke DMM, I agree with FigureItOut that your best bet for automotive purposes is the Uni-T.
Your DMM in series usually isn't going to allow you more than 10 amps, and most of the plug in clamps I've spec'd (like the i400) won't measure anything under 1.0 amps. So if you want to be able to measure more than 10 amps or less than 1.0 amps (i.e. checking starter and parasitic draw) you have to hokey around connecting and disconnecting things. Also consider that the i400 goes for about $130 dollars and the Uni-T is under $35 and the decision, at least for me, was a lot easier.
kblee27
Singapore
I've a Craftsman and Extech.
The trouble with these clamps in automotive application is the clamp.
If the jaw opening is too small, it can't completely clamp a bigger wire.
If the jaw is too thick, it can't get into restricted places a car battery cable is located.
Sometimes you get to clamp a wire and then find out the display is facing downwards or facing a chassis wall you can't see.
WhiffySpark
Check out ruger's post. He has one I keep meaning to buy.
Lately I've been eyeing a vantage
