Collapsed Pole Style Shelter - Negligible Lateral Support
lakeroadster
Central Colorado
Picnic Shelter That Collapsed
driftpin
Wow, it just 'racked' to one side, and the minimal connections failed. Not much to transfer the load from the wall or roof to the foundation.
It might not be as-pretty, but those sonotube concrete pours should go up to the roof beams, and strapping over the tops of the beams fastened with long screws into the sonotubes. They could always 'case' the concrete columns in wood for appearance's sake.
There better be a forensic engineering inspection & report on any other shelters built at the same time.
jives
Central NY
Every new pole barn question should be first directed to this thread. Not that I'm anti pole barn (I've got one and would build another), but as a DIY project it is easy to overlook (or not know) about pin joints, lateral bracing, diaphrams, and so forth.
readhead
Durango, Co.
I'm not sure it is fair to compare the two. A pole building would have some shear built into the walls. It appears that there were no real connections to overcome the moments at either the top or bottom of the posts.
Franz1.0©
Specked by a Civil Servant with job security
Designed by the low bidder
Built by the low bidder
Approved by a well educated & credentialed Government employee.
I have no idea why it failed.
Any chance the roof can be flipped and hauled out with a quad, lot of usable material there.
driftpin
That looks like something someone said, "hey, I can build a shelter roof!", and then did it. I don't know of any structural plans examiner I've ever worked with who would have approved that.
Local jurisdictions have no oversight in federal land. Try to get that design past your local building department and it never would have been approved.
ford33
Chicago, IL. USA
Federal projects require architects and engineers. Usually they do excellent work. Looks like somebody did not do excellent work on this one.
Franz1.0©
US Fish and Wildlife Service- Ranger Sally filling in for Superintendent Biff while Biff is honeymooning with his beloved Lance.
Standard shelter plan number 34860z
Constructed by Metuu minority contractor qualified employees between yoga and Zimba sessions.
Damn nice steel roofing. Probably salvageable.
GMCGarage
It failed because you have a pin-pin connection and no lateral support. Nails and long screws do not offer any resistance to moment.
Oh well. Job security for someone.
ptgarcia
Alta Loma, CA
I wouldn't place blame without looking at plans, first. It could have been a bad decision by the contractor to make a design change because he could do it cheaper and put more money in his pocket. I've seen that happen plenty of times.
billgreenwood
Copperas Cove, TX
I would have to agree with this. The wall girts and metal siding give a full pole building much more strength than this pavilion had.
Sent from my SM-G920V using Tapatalk
73RR
Blank Email
Central Ory-Gun
There will be no finger pointing and everyone will get a raise and a promotion!!!
Just because 'Ol Joe has a contractor's license does not mean he has a clue as to what he is doing. If that was the design on paper then 'Ol Joe didn't even know enough to ask a question.
The up-side is that no one was hurt.
oldmxracer
Was a damn nice looking shelter before it went down !
Think Your close up pictures show why it failed.
Thanks for sharing !
Jamie V
Atco, NJ
I'm not sure about in that area but here in NJ pole barns have the poles down in the ground. That would never had happened if that was the case.
matt_i
SE Michigan
Good post, Lakeroadster. Illustrates the effects of overlooking moment-connections perfectly.
Too bad on the building/shelter. You'd think the Park Service would have the basic skeleton design of these figured out since about the 1920s...then people could do all they wanted in beautifying the basic structure.
MushCreek
Upstate South Carolina
The diagonal braces are too small, and poorly fastened. Whoever built it probably over-torqued them and stripped the wood as well. Once the diagonals failed, the bases didn't stand a chance. Longer nails would have helped, but only slightly. When I built my raised deck, everything structural is through-bolted. I don't trust lags.
red61cj5
West Virginia
This is not a pole barn, pole barns have walls. The killer here was the wide open spaces between posts. Even a metal walled pole barn would have had 2x4 diagonals between posts. This is an example of aesthetics overcoming common sense. Those home depot deck brackets didn't help either. Nice trim though, I like the way even the battens on the gable are beveled at the bottom. Maybe he was a trim carpenter, not a framer.
jives
Central NY
Correct. But my point was that even a rudimentary building -- pole barn or pavilion -- needs proper engineering. A brief look at questions on GJ about pole barn framing shows a lot more questions about pole barn specs than about stick framing. Lateral braces, Y-braces, through-bolts vs. nailing girders, notched posts for girders, pole spacing, post-to-concrete brackets, hole backfill material, and so forth are all question posted recently in GJ regarding pole barns.
My Old Tools
Hamrick Lake, TX
So they built a fake timber frame structure. The real thing would have been mortise and tenon at the joints and the braces. Then the failure point would have moved to the post connection. There isn't enough there to prevent uplift in a stiff wind. That big open roof area is a wing and will generate considerable lift in a strong wind. This is how timber framers build them. 1/4" steel plates are lag bolted into the bottom of the posts and are then welded to the steel posts. The steel posts are later covered with rock.
rburke65
Canfield, Ohio
Hard to believe that that connection was approved by some one and that no one questioned this. Well....maybe they did question it. As said, job security.
L
lakeroadster
Central Colorado
Not Fake "Timber Frame", Poorly Implemented "Post and Beam"
No, actually they built a fake "Post and Beam" structure. A poorly implemented version.
Post and beam uses steel plates to tie members together.
Timber Frame, as you stated, uses mortise and tenon joints, secured together with oak pegs.
If they would have simply used structural brackets at the lateral support attachments, similar to those shown below, using through bolts, and also through bolted the columns to the headers, the building would not have racked over.
For all we know the design specified this, yet the builder decided to go the easier cheaaper route. But as I originally stated:
Such a shame. Without seeing drawings it's hard to know if it was a bad design, or bad implementation. Maybe the construction crew simply used the wrong brackets, instead of the correct style structural post-to-concrete brackets... maybe the drawings called for steel mending plate type brackets at the column to header locations... who knows?
aka Larry
Eastern, NC
Damn, were they planning to park a semi on the roof of that shelter?
teamextreme
Lakewood, CO
One thing to note, while everybody is playing monday morning quarterback and concluding everyone in the government is an idiot and that's what caused the failure, it is probably important to note that we had some helacious winds lately, with gusts topping over 100mph in some places around the state. In fact, the highest gusts ever recorded were pretty close to where lakeroadster is. If a hurricane rolls through Florida, nobody is surprised when buildings are ripped apart, I would guess there were some hurricane force winds at play here.
On the subject of poorly engineered construction, however, it's a bit concerning to see the pic of the post base and the comments that it would never pass inspection. I recently built a pole style lean-to addition and the building dept insisted on use of nearly identical post bases. I did use those Simpson screws instead of nails, hopefully that helps? Mine is walled in and sheeted, so I'm not too concerned, but my building dept spec'd pretty much those exact bases, albiet for a much smaller structure (12x30).
Radix2
the thumb!, MI
In my experience the last thing that inspections will catch is structural deficiencies - especially that type that require reading the directions for specialty connectors, plates, straps, fasteners. The inspectors don't read em, the framers don't read em.
It has a hole, stick something in there...
L
lakeroadster
Central Colorado
Good point. It has been crazy windy.
However where the building is located, it is surrounded by miles of dense pine forest... and the trees tower above the shelter. We didn't see a single tree that had been recently knocked down by winds anywhere in the vicinity of the collapsed shelter.
Here's a photo:
As for what should be used for attachment of the poles to the floor the bracket needs to attach to the column with through bolts, not nails, not lag screws. And those through bolts need to be away from the end of the column.
Something like these.
bjcouche
I doubt that there was excessive wind speeds at play here, I don't see any trees in the photo that were blown down. The fact that there are lots of trees around it also help block the wind force on the building. The concrete brackets IMHO are totally useless for uplift protection. You need something with substantial through bolts and not sheet metal and roofing nails. As to how it got built this way, maybe somebody took their standard walled pavilian plans and just decided that they could simply make it open by not installing the walls. Not knowing that the walls are structural preventing the building from racking. Also without walls, wind is allowed to blow under the roof causing significant uplift. I'm surprised it didn't blow over during construction.
Brian
Brian_WK
NE South Dakota
Here's a photo:
Off topic but what are these brackets called?
Thanks
Brian
teamextreme
Lakewood, CO
With no trees down and surrounded by trees, I guess so much for my wind theory. I wanted to use the post brackets in the upper right picture lakeroadster posted, the imbedded in concrete style. My building dept wouldn't let me and said I had to use the style that bolt to the concrete with a single anchor bolt in the center and are only a couple inches high onto the post. Also couldn't use thru bolts, had to use nails or screws like I did. Very strange considering everyone here is very critical of this style of support, for apparently good reason.
Orionrising
Western Maine
could have been uneven loading of the roof due to snow and wind.... and it sure looks like those posts were attached with roofing nails?
Radix2
the thumb!, MI
Those are the short "joist hanger nails" that idiot framers use everywhere... even though there are only specific places that they should be used.
Then idiot building inspectors demand they be used do they can see the little circled number in the heads...even in double shear joist hangers.
davejo
(VA)
Get the bench builder to build the next shelter :lol:
This local example looks a little better to me. It has a steeper pitched roof so how will it react to wind in comparison?
2 times as expensive?
