Scotsman1886
- Joined
- Jan 9, 2013
- Messages
- 74
I can't access the HF website from work so I can't post a link but its item#63264.
Any opinions out there?
In the hundreds of brake jobs I have done I have never used a "brake caliper service kit"... A 6" C-Clamp and small block of wood does the exact same thing. IMHO...
Mark
I have the larger HF kit with both the left and right hand spindles and it has worked great. I think I only paid about $35 for mine. I see on HF's website they don't list the larger kit anymore, did they get rid of that one?
Ebay kit to the door for less than $16. http://www.ebay.com/itm/12PCS-Disc-...ash=item282920a270:g:iHgAAOSwSv1XkQaf&vxp=mtr
Not sure of the quality but I'm gonna order one for rear calipers. I already use one of the block 3/8" drive rear disc brake tool but it can be a little clumsy.
Yeah, I was looking at that too, but figure the other pieces were for imports that I'll never have. Still, for the money might as well get the bigger one. Plus it has the tool for left-handed applications and you never know what the auto manufacturers might do in the future.That's the 12 piece set. For another $10 you get the 21 piece kit.
What cars are left hand?
So is the rotating pistons something that can be easily damaged?
The ones that aren't right hand. Duh. Everyone knows that.
Yes, the rubbers get stuck. As a side note, this is where maintenance really hits the road. I am not an oil change junkie but I do tire rotation, brake inspection, unstuck parts service regularly. I keep the hardware working and schedule/buy parts for next service and am not scared to change out a piece at a time. I make sure it works,, people seem to throw money at it and ignore where I wear most of it all the way out but it isn't stuck and not working right for last 40k.Curious if the is more info on the pistons rotating. My wife's 2014 Mazda had a stuck slider on the rear that wore the pad out. I noticed the pistons seemed to turn a little when pushing them in. Actually had to take a tongue depressor and push the seal away from the top of the piston since they were stuck at the top and the seal was twisting. The clamp still seemed to do the job just fine with no effort. Was thinking this spring of replacing the rear rotors, all new pads and bleeding the system. So is the rotating pistons something that can be easily damaged?
Thanks for the useful information. I asked because I have never encountered a car with Left-hand pistons.
Not going to work on some cars because it only twists one way. Keep that in mind.
Cheap isn't always less expensive.
