Screwdrivers.
AceofSpad3s
Getting tired of having all mismatched chit, so I am looking to get one set for working on cars/trucks/other chit.
I don't want a set full of fluff to raise the piece count, just enough drivers to work on cars and stuff around the garage. Was thinking of those old proto hard handles I used to see at HRE, but the mixed sets seem to be sold out, all that is left are $50 sets full of flat heads. I just want to spend $100 or less on a philips/flathead set, was thinking of the 8 piece williams hard handle set, but that feels a little small for vehicle work, but I can't say for sure.
I think this set would be a good size sans the bahco drivers.
https://www.toolsource.com/combinat...xt6fudrKuaEs0mcGu4oA23LcIAhrK-0txoaArCT8P8HAQ
If need be I could live with mixing and matching a set of something like those 15 piece proto flat head sets for $50, and getting a set of philips drivers like the williams 6 piece to fill in any spots.
Also looking for a ratcheting driver and some bits. The williams wrs1 still the best for the money out there? Bits wise I'd like a set of torx and hex ones, good quality but don't want to get taken for a ride price wise. Also wouldn't mind knowing a good brand for #2 philips impact driver bits.
pstemari
Seattle
Megapro makes great ratcheting screwdrivers in Canada. Get the one that uses standard insert bits. Channellock relabels a number of them.
I've been real happy with the Proto screwdriver assortment from Zoro. Only minus was the lack of Torx drivers, but SK has Torx drivers with shafts about 2" longer, which I found to be highly useful.
Sent from my Nexus 6 using Tapatalk
pa wrencher
I have a set of Witte screwdrivers. The flat heads been used as chisels the phillips as punches etc. They are still in good shape. They are tough.
Adam.C
When is the last time you needed straights for automotive?
Snap Ons instincts are nice for automotive because their handles let you crack stuff loose. But they aren't perfect for everything.
As a minimum, I recommend a good set of Phillips or Pozis, (0-3) a set of minis (I like my Snap On mini tip sets more than Wiha) and a ratcheting screwdriver set with a good selection of tips. For the few times you need straight tips, use the ratchet. And I prefer the instinct stubby ratchet.
SuzukiGS750EZ
l love my 19 piece williams set. When i was in your shoes a few years ago it was between a witte set and the williams set. The williams set is the same as the older the snap (identical) and the witte set is what cornwell sells with their branding. I like them both.
Tallpilot
Orlando
I like my Tekton set. They have every size you would need for automotive repair, they are made in the USA and they cost about half what the other sets mentioned in this thread do. The handles are different and take some adjustment but they can do both speed or power well if you change your hand position.
One of the things I find very interesting, in this community of tool snobs who take great pride in always having the proper tool for every job, is the use of long handled Snap-on standard screwdrivers as a pry bar. Of course it works but that isn't its intended purpose or design.
wvrailroader
West Virginia
Proto Duratek drivers can be had for a decent price and are great drivers. Mine are holding up quite well and the price is in the range you are looking at. They have great reviews.
Sent from my SM-G930R4 using Tapatalk
rshadd
Doylestown, PA
These Williams drivers have served me well over the years.
JH Williams 100P-6PD
JH Williams 100P-6SD
ecotec
I really like those Williams black hard handle screwdrivers. I think the 19pc, minus the 4 or5 Bohcos, is an awesome set. Those black hard handles, and the Snap-on black ratcheting hard handle would make a perfect set.
Adam.C
No bolsters. Can't comment on handles because I don't own any. Bolters would be a deal killer for me.
Around the house, you can get away with just about any sharp screwdriver. Sometimes on cars, not often by the way, I have to put all my might on the handle to keep the bit from slipping. I usually use a ratcheting box wrench on the bolster to turn the screw.
To tell the truth, the 2 most important attributes of a screwdriver are:
having the right size when you need it
A fresh, not worn out tip
I have sets of screwdrivers in several locations to try and combat the inevitable cussing associated with struggling with stripped Phillips heads
T45
If you have $150 there is alot better ways to spend the money than that.
The williams are nice designs, but you are better of having multiple tip and handle designs in PH2 and torx, electronics, etc than having a complete set of matching screwdrivers. with loads of flats.
$150 is a huge budget and easily will get you top of the line tools.
