Soft jaw pliers
FigureItOut
Bentonville AR
I got these Proto soft jaw pliers in today and I'm thinking I want to try a different pair, so I'm looking for recommendations. The issue with these is the mechanism that allows the jaws to slide between the different width positions. The opening range where it'll stay locked in position is too narrow, so when you open the jaws to clamp around a piece, it starts to slide and gets stuck when you try to close the jaws. The jaws must be almost all the way closed before it'll lock in solidly.
Anyone have good experience with a similar set of pliers? These are 9-1/2" and I'd be looking for this size or even slightly smaller.5e8ec63e9202e43d8475701694d99389.jpg
F
FigureItOut
Bentonville AR
The slip joint pliers are about 10" long. i am usually gripping things around 1.25" diameter.
Cool, I may go with that 3 piece set. It's a lot more than I'd planned to spend. Actually while checking replies I was farting around in the garage and came across a need for the needle nose, so I bet the set would be a good buy.
22george
SW Ohio
Type "canon plug pliers" in ebay.
We used the "ATI canon plug pliers" on aircraft connectors (canon Plugs). They worked great for this application.
WWheeler
Middleofnowhere USA
Here's mine. Boulderfly Soft Jaw Cannon Plug Pliers & Kobalt Magnum Grip Pliers. I've been happy with both.
F
FigureItOut
Bentonville AR
I went a little overboard and ordered 5 different pairs of the Japanese IPS pliers. I'll report back on the quality once I get a chance to use them.
F
FigureItOut
Bentonville AR
These are pretty impressive. They feel very solid and precise. The water pump and needle nose are both spring loaded. The needle nose also have a slip joint design. The slip joints and needle nose pads are kind of a flexible plastic, whereas the water pump style has more of a soft rubber pad material.
rvieceli
Illinois
How "grippy" are the water pump style inserts. I have the slip joint ones and find that the inserts are too hard and tend to slip on the round tubing I want to use them on.
Thanks
F
FigureItOut
Bentonville AR
Thanks
The pads are much more grippy than the hard plastic pads in the slip joints. The rubber is soft enough to deform quite a bit when clamping down. I put a round piece in the vise to check it out for you, and it took a moderate amount of torque to make the grip slip, but this was smooth painted metal, and the handles are pretty long, giving leverage. I think you could tighten say galvanized pipe snug enough, and loosen it if wasn't stuck pretty good.
There's two water pump style versions, the 250 and the 270. The jaw design is a bit different. I don't have the 250's in yet, so I'm speaking of the 270's. At their most narrow jaw setting, they'll just barely clamp onto 3/4" copper pipe, so they wouldn't be effective on anything smaller.
F
FigureItOut
Bentonville AR
FigureItOut, with those API pliers, how much clearance is there between the grip surface of the plastic jaws and the top of the metal screw head that holds the soft jaws in? If you clamp a little too hard would the screw head scrape up the item you are gripping?
There's lots of the clearance on water pump style with the rubbery jaws, I don't think you could scrape anything with the screw. On the other styles, the screw is not recessed very deeply, but the jaw material is a much stiffer plastic, I don't think it could compress enough. I do worry about the wear though, it won't take much material loss to cause an issue. It does seem though, that the screws are not in a key wear area, but it's something to watch. bf81259ef9f2486a062b36e2d1afe449.jpg
