Need ideas for alternative backsplash for corner sink
dragonballz
Massachusetts
I have a very small half-bath with a very small sink in the corner. Currently, there is just two small slabs of marble acting as a backsplash, 3/8" thick, that I'm thinking of removing. My current faucet is getting corroded. It is a cheapo faucet. Being in the corner, I'm having a hard time finding a replacement faucet with handles that will fit.
https://media.deltafaucet.com/SpecSheet/DSP-L-B2515LF Rev D.pdf
This is the new faucet I bought. The measurements are 222mm from handle to handle. It will not clear with my current backsplash. Is there some kind of waterproof paint or something that can act as a backsplash to give me the clearance?
Thanks
Boomer343
Wouldn't it be easier to buy a single handle facet with a cover plate? Lots available.
tjdux
Southern Nebraska
Buy a small sheet of aluminum or stainless steel, bend it, put countersunk screws in the top and silicone to hold it at the bottom.
Sharpest
South Texas
I used a 12" aluminum door kick plate behind my sink. Cheap, zero fabrication required and large enough coverage for my needs.
gungatim
west mich
cut a piece of laminate and use contact cement. they make fancy brass or chrome edges if you want it to look super-professional but silicum caulk works just as well...
Voi
Western South Dakota
The do make vinyl films made to look like tile that are used for back splashes. But I like the door kick material idea better.
bushmechanic
I like the polymer tiles that look like metal, marble, wood, or whatever. They're designed to be used in that environment, and are only about a couple millimeters thick.
There's one for every room and taste.
rburke65
Canfield, Ohio
I used a white laminate in our kitchen. We never have to be concerned with splashing anything. Wipes right up! Lots of options out there.
D
dragonballz
Massachusetts
For the laminate, it seems like i'll need to do the whole wall to make it look good. I'd like to only do the lower backsplash area, immediately near the faucet.
CGT80
IE, SoCal, USA
Semigloss works fine, just use a decent paint and put plenty of it on. Most people leave the surface too dry when brushing or rolling. Gloss does clean up easier, but it shows more imperfections and may not be the look you are going for.
I hate two handle faucets. Single handle makes much more sense and would serve two purposes in this case. Also, 1/4" for the current back splash is not much. If the new material was 16 ga aluminum or stainless, you would only gain 3/16". It seems like that is still a tight fit, and is it going to make awkward to use the faucet?
gungatim
west mich
you don't have to do the whole wall, just a section. that is what the stainless or brass trim is for, it slips under the laminate and gives a finish edge. google image search for laminate backsplash and you'll see what I mean. I did this in our master bathroom with laminate that matched the counter just 4" high so I didn't have to bump out the electric receptacles...there are a million color/pattern options available--some look like granite, stone, solid color, contrast, stainless, whatever you want. it can look really nice, cheap, easy, and thin enough not to worry about...also easily removable.
D
dragonballz
Massachusetts
Is the problem that the handles hit the backsplash ? If so why not take them off and turn them towards you until they clear ?
Yes, the handles hit. Wait... is that what those set screws in the handles are for? I assumed the handles had a keyway.
D
dragonballz
Massachusetts
Oops! The current backsplash is actually 3/8"
