Some people just have to abuse tools. Some examples of ratchets in pawn shop:
There is the "use the ratchet as a hammer abuser." One Duralast(pretty good import tools) was well used, including the selector lever being broke off. Other than that, the ratchet probably would work just fine with a little lubrication. I can see the temptation to hammer with the ratchet if in a hurry, but not with the side with the selector lever.
Then there is the user who has to put a cheater pipe on the ratchet. One no name import 1/2 inch drive RH ratchet had the handle bent from the pipe. Yes, the mechanism was broken, but I have seen cheaper ratchets with the handle bent but still working. More commonly I find ratchets with the gear(s) broke. Those naturally I pass up, but have gotten them to saw the head off, making a large punch. Another pear head no name seemed to work fine, but the hammer guy must have used this one and broken the selector lever completely off.
At the other end of the scale, there must be many guys who buy the cheap set, usually 3/8 drive, and never use it. I see a lot of RH cheap ratchets for sale by themselves that show very little use.
KEH
KEH
