Help with Kobalt ratchet
TDRucker
I have a Kobalt 04030 1/2" ratchet. It is one of the early ones made by Williams. The problem is that today I dropped it and it landed just right to crack-off the little lever that switches the ratchet action. Busted clean off. I can remove nuts and bolts forever but I kinda would like to actually put things back together.
Does anyone know where to get repair parts for these? I have looked everywhere.
I had heard that some Snap-on or Williams kits might work as well but I cant find any info on these.
Any help in locating some repair parts would be greatly appreciated.
Thanks in advance.
AlD
I would just buy another ratchet off eBay and either keep it, or use it for parts. No one is going to stock parts for that thing. Good luck!
Al
mikebaker1129
Huffman,TX
I am pretty sure parts are nonexistent ,but the same ratchet was sold by Bahco and Harley Davidson.
I have not found a kit made by Williams that fit the Kobalt -Williams ratchets.
T
TDRucker
Thanks for all the tips. I think I am on the right track and I really appreciate the help. I have a hard time throwing things away if I can make them work. I will follow up on these leads and see if I can't get it working again. Fortunately I have my trusty fine-toothed SK standing by but I really liked the feel of the Kobalt.
If I come up with a good solution I will post in case anyone else has the same problem.
Jason280
I'm not positive, but you should be able to take it back to Lowe's and get a warranty replacement.
ihateminimumwage
Yes,but it wil be a Asian ratchet for what was a decent ratchet.
The Taiwan made Kobalt (especially the low profile ratchets) are surprisingly nice. I warrantied a couple of Danaher era junk Kobalts for them, and they worked great.
Williams outsourced that older design to Taiwan (also sold as Blue Point) with enough changes that I sincerely doubt the import kit would work, they just kept the overall look the same. The USA Williams pear heads were all swapped over to the 36 tooth Snap-on mechanism, so no clue if those kits would work either. Might have to experiment and see what works, but that could get expensive quick.
T
TDRucker
All really good points and I thank you for them. The internals on my Kobalt look just like the 36 tooth internals on some of the repair kits that you all have suggested.
There is a local professional tool store nearby and he carries Bahco, Knipex, SK, etc. and some other good brands so I will go see what he can cook-up.
I went into Lowes tonight to see what would be the warranty swap and there was a 72 tooth and a 90! tooth that were both made in Taiwan and looked decent. So based on the advice I have seen here regarding the Taiwanese made tools. I will probably go that route unless the tool guy performs a miracle.
Thanks again and keep on wrenching. Oh, Jason 280, based on your avatar, I think you might want to see what is in your water!
mikebaker1129
Huffman,TX
The selector ,pawl and pawl screw on a 36 tooth duralast ratchet fits in my kobalt ratchet just fine.
Mine is a 3/8 drive FWIW.
The Williams USA 1/2 repair kit comes with a new selector which will fit but the screw may need trimmed, or the Snap on version which may be cheaper at $10.
Jason280
If you need a 1/2" ratchet, let me know....I'm sure I have an extra one laying around I can send you. I thought I may have one of the older Kobalts, but can't find it. I may have a newer one, have to check through the "extra ratchet" drawer.
