kasander
Hello all, I've been lurking here for a few months reading everyone's build threads and am finally ready to kick off my own build. I am building a 26x30 garage with a stick built roof to maximize space upstairs for a future studio apartment. I welcome any feedback from you experienced guys along the journey.
Here is a summary of my requirements that drove this design:
26' depth because the garage at my last house was 24' and I needed a little more room to park my boat trailer straight.
30' width to have 2 garage doors and additional workspace and room for stairs
I want stick built roof to maximize square footage upstairs, hence the functional dormers front and rear.
Separate entry for upstairs for possibility of future rental as AirBnB or to a college student.
10' garage ceiling (possible future lift and storage of 9.5-10' SUP boards)
Monolithic slab (No block work, concrete work done in one shot)
No support columns in garage (Hence the W12x50 beam)
Not so massive that it looks out of place behind my 1 story ranch with 3:12 roof pitch. (I might have missed this design criteria...)
Here are a few renderings:
Front view:
Back view:
3D representation:
https://sketchfab.com/models/a82560ab1552418881e952f4649cc013#
Architectural plans:
http://www.pelicanpointroad.com/garage/garage_arch_plans.pdf
Thanks to Cory at 2x4 Designs in Wilmington for the architectural work!
Engineering plans:
http://www.pelicanpointroad.com/garage/garage_eng_plans.pdf
Thanks for Doug Jones Engineering for the engineering plans!
I have changed the slab to be 8" above grade to eliminate the need for pressure treated sheathing. The other deviation from the plans I was thinking was to use full 10' studs. This will make the garage ceiling height 10' 5.5" (1.5" bottom plate + 1.5" bottom plate +120" stud + 1.5" top plate + 1.5" top plate -.5" drywall). It seems studs are available as either 117" or 120". At 117" the wall would be 122.5" which would leave 2.5" gap with 10' drywall sheets. Might as well make is a 5.5" gap and get the extra height. (I am thinking of maybe putting in a lift at some point years down the road).
I will be attempting to do most of the work myself, so will welcome any tips along the way.
I have staked the location in the backyard and am meeting with the concrete contractor tomorrow to review. They are planning to start work on footings and slab prep next week.
This leads to my first questions:
Is there anything I need to think about before the concrete is poured?
I have permit and termite treatment covered. I am also leaning towards flat, level slab as I will not be bringing wet vehicles in often. I have asked it to be slick (not just smooth) finish. I know it will be slippery when wet, but I hope to insulate and install HVAC eventually. Slick should be easier to keep clean.
Engineering plans specify 4" thickness, 3000psi concrete, but I may ask for 5" and 3500psi based on all the conflicting information I have found online...
I am thinking the only thing I need to add is a water supply and drain line stubbed up through the slab. I will tie this into my house water and sewer lines later. I am thinking I will have a separate power feed for the garage which will come through the wall, so I don't need anything there. I may run a piece of conduit up through the slab for ethernet or coax cable from the house.
I also thought about running a pipe through the slab and out the back for future air compressor outside. I will eventually put a lean-to shed off the back to store lawn and garden type stuff and was thinking about putting a compressor there as well. I was wondering if running air line under the foundation would just fill up with water and be a bad idea?
Anyway, I'll stop for now, but thanks in advance for any advice and tips!
Keith
Front view:
Back view:
3D representation:
Engineering plans:
Keith
