Any SAE on Vehicles?
joe_padavano
Northern VA
1986 to 2002 vehicles.
Any SAE on these and newer vehicles?
Certainly up to 2000 there are SAE fasteners. My 1999 Chevy truck with 454 uses SAE on all the engine fasteners and metric on most of the rest. Pretty much any vehicle with a heritage engine used SAE fasteners on those items. The rest is hit-or-miss. GM used SAE fasteners on the suspension of their heritage RWD full size cars through 1990, and possibly through the end of production in 1996.
jeeper46
Canton, Mi
I worked at Hydramatic. The THM400 transmissions, and all the later iterations of that model, were all SAE, right up to the end in 2010. Likely the THM 325 was SAE also, being just a 400 that was modified to be FWD. Every other transmission that came later, starting with the THM 200 around 1977 or so, was metric.
ihateminimumwage
Pickups and vans (the non-mini type) from the "Big Three" definitely held onto SAE longer than their cars.
Teenager with old tools
riverside california
2000 impala with the 3800 engine has a couple sae fasteners you'll encounter when doing a top end rebuild. Almost everything on the car and engine is metric however
dnschmidt
Phoenix, AZ
On my 3800 1998 Pontiac Grand Prix it was always take a guess with respect to metric/SAE bolts and nuts. Mostly metric with a bunch of 5/16 thrown in (upper intake manifold) along with other SAE sizes. I don't think this stupidity ended until 2010 or so. Now it's all metric but for the longest time all of the legacy stuff (like the 3800 V6) was whatever it was. DROVE ME NUTS! At least on my 911 and on my Sonata I don't have to guess what size the fasteners are.
md21722
Mt Juliet, TN
As the years go up less and less SAE on domestics. Take Jeeps for example, TORX fasteners went up, as did metric through the suspension, but axles and the 4.0 motor were still SAE through at least 2006. Two starter bolts, one metric, one SAE.
davethorik
Norka, Ohio
My first car was an 89 lesabre with the 3800. I remember the water pump bolts were half metric and half sae.
bczygan
DETROIT! Arsenal of Scrappers
Rats!
I was hoping to leave SAE out of the service cart.
Vehicles are:
86 Pontiac 6000
90 Pontiac 6000
95 Chevy Astro Van
99 E350 Ford Econoline
02 Chevy Astro Van
Where would SAE show up on these?
Bill
Whitworth
There are always assemblies and components from OEM suppliers that will use SAE. Plus there can be aftermarket parts too.
APEowner
Sunny, New Mexico
Rats!
Vehicles are:
86 Pontiac 6000
90 Pontiac 6000
95 E350 Ford Econoline
95 Chevy Astro Van
02 Chevy Astro Van
Bill
That whole fleet is more or less SAE engines in metric vehicles.
maydaymike
Mostly SAE with a little metric thrown in here and there on my 2014 Harley-Davidson.
Sent from my HTC One_M8 using Tapatalk
Advan
Ontario, Canada
Rats!
Vehicles are:
86 Pontiac 6000
90 Pontiac 6000
95 Chevy Astro Van
02 Chevy Astro Van
Bill
Yikes! What are you, the service guy for a Michigan version of Trailer Park Boys?
RPH
Michigan Thumb
Just buy a set of metrinch tools, fit both metric and sae. Just fits both poorly but that gives an opportunity to purchase tools to remove stripped fasteners. I see a win -win here. New tools and new skills.
Murphy4570
West Deptford NJ
American manufacturers started switching in the 1980's. Expect from there on to have mostly metric fasteners for body and suspension/chassis. Drivetrain will switch from SAE to metric as the old engines are phased out in favor of new designs that are metric.
Example: Ford used the old 302/5.0L V8 in the Explorer/Mountaineer until 2001. That engine design dates back to 1962. All SAE fasteners on the basic engine parts. The 4.0L V6, and the 4.6L V8 introduced in 2002 model year, are newer designs, all metric.
mbshop
visalia ca
As a mac dealer in the late 80s I was selling more and more metric to mechanics, specially to farm equipement manufacturers. They were changing to metric so they could export machinery.
md21722
Mt Juliet, TN
Yep, same with Chrysler/AMC/Jeep. They did not rethread existing engines to metric. Everything that ever threaded into the head or block of the Jeep 4.0 was SAE. The water pump to block bolts are SAE, the pulley to water pump bolts are metric. Lots of 7/16, 3/8, 1/2, and 9/16 on that engine.
Schurkey
The FWD version of the TH 400 was the TH 425. The 325 was a downsized FWD trans which may or may not have been based on the TH 350.
They started switching earlier than that. I'm thinking the '78 "A" body had a mix of SAE and metric. Fairly sure the Chevette had some metric from when it was introduced in...'76?
jeeper46
Canton, Mi
Oops-I forgot all about the 425-I think I only worked on that line for just a day or two. Back when I started at Hydramatic, The Assembly Room had two 400 lines, two 200 lines, the 425 line, and two 125 lines. That was when there were 14,000 people working there.
ex-x-fire
Sheboygan Falls Wi.
Yep, if the part or assembly was designed after 1977-78 then it should be metric, but the auto makers arent going to retool existing components to make them metric.
Sam'sAutoParts
Northeast PA
My 86 Chevy pickup is all SAE.
Actually they are a few metric fasteners on the square body's believe it or not. Starting in 1978/1979 or so they started to creep in. The metric is mostly confined to items that would not normally be removed but I have to keep a few metric sockets in the kit for complete strip downs.
I bought a 98 jeep XJ this summer and almost immediately realized it was a 50/50 split in SAE and Metric....
