Thanks to everyone who viewed or chimed in with opinions on the RaceDeck plans for my garage.
I just completed the floor this morning about 6 am. It was just me doing the deck install all night, so it took a bit longer than I planned, but it turned out great. I still have a little trim to do in a few places, but that should not take too much time.
The hardest part was getting everything out of the garage. This took a couple evenings. While everything was out, I decided to put garage floor paint on the stepped areas around the garage to have a nice clean appearance. I also painted about 1.5" from the edges on the main floor, so it looks clean with the 1/2 " gap from the RaceDeck to wall edges (the 1/2" gap is for possible expansion). I also painted the little strip of concrete in front of the garage doors to driveway, and a few inch stripe just above the stepped areas inside the garage, so when the steps get decked, it will all look clean on the bullnose step.
While I had all my shelving out, I decided it was a good time to clean and paint the walls. I went with a grey/silverish color to somewhat match the alloy racedeck color as well as my shelving and craftsman pro box. I will paint the rest of the garage soon.
I would recommend removing everything from the whole garage to do this, as if you were off a little bit doing it one side at a time, it might make the whole place off a little in the end. There were a few times I had to shimmy the floor deck floor during installation to get the spacing from the walls corrected as the tiles tightened up as more got connected, and the larger the floor got, the tougher the shimmying became. If I had been doing one side at a time, this would not have been possible.
As for the quality of the product. I had ordered some extra pieces as "cheap insurance" against any potential product issues. I can happily report that out of the 600 or so pieces I installed, every piece was perfect, I did not need any of the extra pieces at all, all quantities and colors were received as ordered. I did put some landscape cloth under it to keep noise down, and even with nothing in the garage, it is pretty quiet. I used a Large rubber mallet to lay the tiles, and it made snapping them together very simple. Oh, in the package, was a free shirt, and a couple stickers. SWEET!
INSTALLATION HINT: Use a soft grip when you hit them with the mallet, and let the weight of the mallet do the work, not your arm and they snap together quicker/easier. Wish I knew that trick in the beginning. Also, as you lay the tiles, do not kneel on the tiles you have already placed, as this sometimes makes it a lil more difficult for the floor to flex and snap together.
I did have some cheap labor (Kids) to help move stuff and prep before they had to go to bed, a little later than normal, but the help was appreciated. I would definitely recommend having a helper to lump the tiles around while you lock em down. This would have saved a tremendous amount of time.
All in all, the install is simple, and the real work is in the preparation of the garage.
All tiles are RaceDeck CircleTrac: Black, Red, Alloy, Graphite.
Here are some pics of the project.
View media item 68816View media item 68815View media item 68814View media item 68813View media item 68812View media item 68811View media item 68810
Now that I have got a few hours of sleep, I will get back out there, finish the trim pieces, and start putting everything back. UGH !
Once, the main garage floor is complete, and everything put back together, I will begin on the workbench area and side entry areas.
Let me know your thoughts. Thanks for lookin.
Jason
