oldironfarmer
Andy keep the foundry going. If you get back this way I will take you to see a friend of mine who runs a small foundry if he is still in operation. You can pick his brain.
That would be great fun! Thanks!!
Andy: still trying to catch up after the WEDDING. looks like you've been pretty busy staring down the bull, playing with the calves and opening up OIF'S foundry.
The wedding was a rather major event. Even on GJ
i had to laugh about the broken rubber boot on your gear shift letting the air in. Sub's fix actually helped me too cause i've got a Stairmaster Kyak machine that has a broken rubber boot over a very greasy joint that i'll just wrap a rag around now if i end up using it or selling it. or is there a supply house for big rubber boots cause i think the Stairmaster one is maybe 3 inch diameter and UNOBTANIUM now?
I guess I'm glad you have found humor in my misfortune.! I guess you could get in quite s row over the broken boot...
yes keep the foundry talk coming in case you didn't know there are others that would like to know more about this and good to know the safety tips you know like putting sand on melted metal instead of water and things like that.
Well, I'm a novice, but I'm sure going to try
have a great day working out in the SAND PIT at the FOUNDRY while i head to the SALT MINES on my SATUR day.
cheers
Go ahead, rub it in that you're earning money while I'm spending it. Maybe we should get together, I can spend some of your money.
I like how Bob thinks. Making a female mold for silicone or urethane boots is actually quite easy. Urethane is a little harder as it tends to be a little watery so the mold needs to be moved to keep the coating even whereas silicone can be ‘painted’ on. However knowing Andy I would up the stakes to a rubber vulcanising setup. Un-cracking some long chains eh?
There's a thought. I have made lots of silicone molds, I suppose I could make a silicone bellowsThat would be fun...
Though boots that size can be pilfered off almost anything these days. But I have to warn you that it is a very slippery slope Andy! Once you have a new boot you find a problem with the firewall. Fix the firewall then you want to tidy up the instrument panel. Then find the front columns are draining water into the vehicle and that is why the floor pans are rusting out… where will it end?![]()
Well, there is no firewall, there is no instrument panel, there are no front columnsYou raised the bar so high I can't see it.
Maybe you can just knit a little sock for it?
Well that wouldn't keep the air out, now would it?
+1 on keeping up documenting the foundry work. I like the idea of the burner tile incorporating the nozzle flare. Do you plan to build the bracketing holding the burner into the enclosure?
I'm thinking the burner will just be propped up outside, but it may need a foot. Gravity should hold it into the burner tile.
Since you are creating a bit of structure it may pay to think about a small casting crane to help manage the crucible by yourself. Will let you comfortably do bigger castings so you can focus on controlling the pour without trying to keep your mind of you hernia as well. Even 5lbs of metal + crucible get quite heavy on the end of pouring tongs when you are trying to tip it out slowly. Otherwise I’m all for resistance training.![]()
Yes, at some point a casting crane needs to be in the works. Primarily for safety with the hot metal, even if I were to have a cramp at the wrong time I could get burned, or a heart attack, phone call, etc. I keep waffling on what to build. It would be nice to avoid a conventional hoisting device as that is usually slow and time is of the essence when you are getting the hot metal to the mold. Once I get the roof up I should be able to hang it from there. I like some kind of an idea where I can use a lever to lift the crucible and set it in a cradle that is pre-positioned for the proper pour spot. The larger the crucible the more time you have to position it.
Bar I was using today is 7/8" about five ft long. My favorite is 1-1/4" with point one end and blade the other. It tamps well. It's blacksmith made (not me) and has a U in the middle for a handle.
