Not a pro, and don't even do tons of work on the cars but I expect that to change a little as we are starting to think about a vehicle for a soon-to-be teen driver. I currently have a Milwaukee full-size M18, non-fuel impact which does everything I've needed--as long as it fits. And for example it doesn't fit to remove the caliper bracket bolts on my wife's Escape.
I saw the new mid-torque Fuel impact online and stopped at a local Milwaukee dealer but they only have the compact Fuel impact. Loved the size of it but only rated at 220 ft-lbs so I'm wondering if its enough to break loose rusty suspension hardware and the like. The mid-torque is rated the same (450 ft-lbs) as my current one but looks to be a good bit smaller but I can't say for sure.
I'm now wondering if I shouldn't buy the compact and keep my current one in the back of a drawer for heavier duty use. Looks like the only way I can see the mid-torque is to order one online as no one in Metro Detroit seems to stock it.
I'll be buying with batteries as my current M18 batteries are several years old and showing their age.
Will the compact break loose lugnuts on most cars and SUV's?
I run them down with my impact about 1/2 throttle and use the torque wrench after it hammers about 3 clicks. What the tire shop does I can't vouch for...
How does the size of the compact and the mid-torque compare?
Professional Technician here, and I use the Fuel full size 1/2" impact for wheels, subframe bolts, anything else that requires a lot of oomph. I also have an IR 231C air impact that I have as backup, and use in cases where I need a lot of power but don't have space for the electric. I'm not sure if air is available to you, and honestly I based my decisions around having both to begin with. I also have the hex drive m18 fuel impact, and chucks for 1/4", 3/8", and 1/2" for that. I don't really use an impact on caliper anchor bolts most of the time. I just use hand tools and a torch if necessary (isn't usually).
Also, not to start a war, but I would not recommend what Hammer1963 is suggesting. I run down lug nuts with my fuel in the 100 ft lb setting all the time, and always torque them with a torque wrench as well. Depending on the wheel and lug nuts, they're usually between 40 and 85 ft lbs. after hitting them with the impact. As measured with a Snap On Techangle ATECH3FR250B torque wrench. Definitely not consistent or tight enough to torque customer wheels with.
My suggestion, if you don't do that much work and your current impact works for most jobs, would be to run it until it dies, the batteries are dead, or you need something more capable. Especially since you would have to invest in new, expensive batteries. However, if you just want to get something nicer, I doubt you could go wrong with any of the Milwaukee Fuels.
I've got and M18 circular saw, Sawzall (mostly used for tree trimming these days) hammer drill and the workshop blower I use for getting water out of the crevices on the cars after washing. The blower seems the most use and the batteries are lasting just long enough to blow water out of the crevices on one car. They are really suffering on the circular saw and are only recharging to 3 bars. 2 of the 5.0 batteries will run me $260, the compact impact with the same batteries is only about $60 more and the mid-torque is only about $140 more.
Do the 3/8 M12 ratchet and 3/8 M12 impact even have a place in an automotive garage?
Thinking of picking up the $199 set from HD but the 3/8 impact only has 116ft lbs and the racket I think is 35ftlbs doesn't seems like they will do much with bolts.
I have the M18 fuel impact drive I use with a 1/4 hex to 3/8th adapter but that takes up so much space especially in cramped places.
I literally never use the 3/8" ratchet. Probably one of the most useless tools I have purchased. As said above, it doesn't break hardley anything loose at that torque. I use my impacting air ratchets instead and they are light years better..
