My concrete block foundation wall in the basement comes up one block in my attached garage. I want air in both places. Right now I only have a 4 gal double hot dog that weighs 58 lbs. It is a bit heavy for me, at my age to carry it back and forth. The compressor lives in the garage. Eventually it will be replaced with a real 5 hp, 2 stage on a 60 or 80 gal tank that will live in the basement and the air will go the other way. The distances are very short. I was thinking of using a piece of copper pipe with npt threads so I can easily re plumb in either direction. I want the pipe well anchored but I prefer not to cement it in, in case of changes in pipe size, material, etc. I thought there would be some sort of split clamp integrated with a flange that I could screw to the wall but i found nothing. The closest I found was a split hanger that hangs from threaded rod (1/4-20?). I thought of bolting it to a rt angle bracket, screwed to the wall on one or both sides of the wall. I can get clamps in any pipe size. I would use silicon sealer to keep fumes and drafts out of the basement. It is not natural gas or water so I hope code is not an issue. Anybody know of better hardware that is more purpose built for the job? Thanks.
