Parts washer and winter..
Keel
LaLaLand
Before I try to re invent the wheel..
Is there a product for this..??
My garage is not heated.. and I now use a water based parts cleaner like purple power..
Do they make an antifreeze additive so it won't freeze in the winter..Or am I on my own of trying r.v. type water line anti freeze?
And mix it with the cleaner..
Cause frankly draining it every year and not being able to use it for 3-4 months gets old..
I even thought of maybe a mini solar water heating system to keep it from freezing..
Idea's /options. other than move.. or heat the garage..
I even thought maybe a vehicle block heater.. just not sure how it do with the **** it cleans of the parts being near the block heater unit..
Show7d3
Flush the water out with RV antifreeze. That will keep things from freezing and protect the pump.
Warrenator
Newberg, OR
I bought a stick on silicone pad heater (block heater) off amazon (15 bucks, 250 watts, it is about 6 by 4 inches and works really well) and a thermostatically controlled outlet (on at 35 degrees, off at 42 degrees, also around 15 bucks off amazon). Keeps it from freezing, if I just want to heat up the cleaning solution I can plug it straight in to the wall. Works better heated of course. The silicone pad just needs a flat area to stick on to.
Or just use solvent, it doesn't freeze.
david3921
Wyoming, Michigan
Do a search on Amazon for bucket heater. There is a lot of stuff out there designed to to keep water from freezing for livestock.
