Bill, your tool list is most impressive. Can we see a few photos of your collection. Are you planning to open an auto repair shop and tool loaner service in Detroit?
Just want to have the right tools when I work on my vehicles ad things around the house.
A couple of years on GJ and most of this stuff just follows me home.
A selection of the most usable for vehicles, is in the HF 5 drawer service cart. The rest in the 44" HF roller or my 1 car garage and 4x8 shed.
With some exceptions, I think it is a basic but somewhat complete kit.
It is heavy on sockets and wrenches and short on electrical and diagnostic and AC and fuel things. That's what my other list of wanted items is for.
Enough, almost, to do much except trans and engine rebuild work.
But think about it for a second. Don't you really need most of these things, and quite a few more?
Photos later.
Bill
Here's the wanted now and later list:
Potential tool list:
Next on the list:
4 Pc 3/8 in. Drive Impact Socket Extension Set HF 67926 7.99
4 Pc 1/2 in. Drive Quick-Release Extension Bar Set HF 61968 22.99
Dental picks
Sockets handle trays, deep metric to 27 shallow too.
Electrical Terminal Kit and Crimper
LED 12 volt for testing coil on plug, etc. ($3 or so at electronic supply house)
Scanner wide data logging Actron CP9135?
3 in. High Speed Composite Air Cut-Off Tool HF 68832 19.99
Astro Pneumatic 9401 10-Piece Snap Ring Pliers Set APT-9401 28.99
Mapp gas - CL
External retaining ring pliers Matco
45 Pc Titanium Nitride Coated Alloy Steel SAE Tap & Die Set 61411 84.99
45 Pc Titanium Nitride Coated Alloy Steel Metric Tap & Die Set 61410 84.99
Irwin damaged fastener tool set Screw extractor set?
IRWIN Tools BOLT-GRIP Deep Well Bolt Extractor Set, 5-Piece (3094001) 34.23
Stainless Steel Tweezers Set 6 Pc HF 93598 5.99
Wrenches long box end metric
Offset Box Wrench Set Metric 8 pc HF 32042 15.99
Offset Box Wrench Set SAE 8 pc HF 32041 15.99
Shallow sockets
Thread restoration kit Craftsman SAE and Metric 48 pc 971 2750 54.99
Hex sockets ball end long 3/8" SAE HF 67885 14.99
Hex sockets ball end long 3/8" Metric HF 67888 14.99
Hex sockets 1/2" impact 8 pc SAE 67893 29.99
Star sockets 1/2" impact 8pc HF 61336 29.99
Better organization for wrenches
SAE everything...
Factory service manual 2002 Astro Van
435.00
For Service Cart:
Mount for nitrile gloves
Mount for paper towels
Mount for
Shelf
Side cabinet?
Electrical outlet
Air hose rack and fitting
Working on better storage for service cart. Took numerous things out of packaging to save space.
Would like:
1/2 in. Drive Impact Flip Socket Set 3 Pc HF 62491 11.99
1/2 in. Drive 25 in. Professional Breaker Bar HF 62729 19.99
1/2 in. Drive 18 in. Breaker Bar HF 67932 9.99
3/4 in. Drive 20 in. Quick Release Breaker Bar HF 98270 21.99
Titanium Nitride Coated High Speed Steel Step Bit Set 3 Pc HF 60379 13.99
11 or 18 piece brake caliper set HF?
Disc Brake Pad and Caliper Service Tool Kit 18 Pc ABN Sears 24.99
Bearing Separator and Puller Set HF 62593 49.99
Master Fuel Injection Pressure Test Kit HF 62788 89.99
1/2 in. Drive Front Wheel Drive Axle Lock-Nut Socket Set 7 Pc HF 62842 39.99
1/2 in. Drive Super High Torque Lug Nut Impact Socket Set 11 Pc HF 62899 69.99
Silver And Deming Drill Bit Set 8 Pc HF 61892 34.99
2 Pc. Professional Automotive HVLP Air Spray Gun Kit HF 61472 49.99
Helping hands HF 60501 4.99
Small MIG welder
Air chisel
Spring compressors - Would like center one
Interior body panel tools -
Have HF plastic - couple more HF
Short and long wobble extensions -
Have some
Deep sockets -
Have some
Oil Filter Wrench (assortment of strap and cap types) -
Have some
Extensions locking and 3/8 -
Have some
Special pliers cable cutters -
Have some
322.00
Not needed yet:
Stubby wrenches
O2 sensor and oil sender socket set HF
Rear caliper cube - Not needed
Cordless impact - Not needed
Offset wrenches box end metric
Quick disconnect tools
Axle nut socket set powerbuilt O'Reillys?
Body panel clip pliers HF 67399 7.99
Push pin pliers HF 67400 9.99
Leslie blind seal puller
CV joint boot band installation tool
Air chucks for pressure testing cylinders
Compression tester
Fuel pressure gauge
Vacuum gauge
Chain Wrench
Roofers magnet -
Use HF magnet bar
Stud remover
AC tools
Disconnect tools
Hex shaped connector removal tool
2nd cart
Hose cutting tool -
Use utility knife
Hose disconnect tools HF
Really long 90 degree pliers
Big channellocks
Curved needlenose
Heavy Duty Slide Hammer and Puller Set 16 Pc HF 63268 69.99
wrenched chopped wrenches S wrenches
Eastwood pro flaring tool set -
use small set
Specialty wrenches
Brass rubber mallet HF -
Have separate ones
Cable actuated hose clamp pliers
Bolt-Type Wheel Puller Set HF 62620 14.99
MAC flare set
Balance puller
Block tester
Noid Light and IAC Tester Set 11 Pc HF 97959 39.99
183.00
