Good morning all,
Thanks for all the advice and suggestions. Just a few quick questions:
1) Ratcheting screwdriver - I can get the snap-on soft grip standard for $34.00....should I go with that or another brand?
2) Punch and Chisel set - I'm thinking the MayhewPro 14 pc set.....any thoughts on the selection?
3) Impact sockets - Wright
Regarding impact sockets, what's a good mix to start out with? Should I get shallow and deep (SAE & Metric) for 3/8" and 1/2" drives? I'm thinking about getting shallow and deep universal sets? Thanks for the help!
These are all just based off of what I've worked with, not the end all answers.
1. Can't go wrong with the Snap-on ratcheting driver. I bought my hard handle with the SEP discount, and used it all the time with shop work (not so much now in a service truck, way easier to lose a bit than an entire driver). Even if you were to hate it, you can flip it used for more than you pay with the discount. IIRC I helped pay my way through school reselling some of them since SEP let me order all the different colors.
2. Be very picky which Mayhew set you order. Pro should be good, but I made the mistake of ordering one of the cheaper sets, and while the punches are good, the chisels are soft garbage. I have Proto Los Angeles chisels that are well over twice my age that I use and have never had to sharpen. The difference in good and garbage chisels is insane when you actually can feel the difference side by side.
3. Shallow and deep in SAE and Metric in 1/2" and 3/8" and U-joints will do you great (I've been hammering on the Sunex 3305 adapter/joint set professionally for years with zero failures).
Universals are great in 3/8" for tight spots and to keep a socket from flying across the room if it slips off the fastener a bit. Personally, I'd skip Wright for universal impacts since they use that odd ***-backwards design that puts all the bulk at the fastener end.
Stick with impact for 3/8" and 1/2", skip the chrome. Pick up a good 1/4" chrome set for smaller stuff, and 3/8" mid length/Semi-deeps for the occasional tight spot where the impacts are too fat to fit.
ecotec,
Thanks for the helpful suggestions. I'm just curious about your Hex and torx sockets pick....why Snap-on instead of Wright?
2) Screwdriver set - The snap-on combination, Instinct hard handle set is $55.00 for students....Should I just go with the snap-on set or still consider the Williams 19 pc set? Thanks for the help.
Screwdrivers are all going to be personal preference of how it fits in your hand. I got by just fine with clear Craftsmans and old yellow handle Protos and Williams for most of my adult life, moved up to Craftsman Pros, tried out Williams black hard handles, Wiha, and friends/coworkers SK hard handles, Snap-on Instincts, MAC comfort grips and Proto Durateks. Finally settled on the Durateks and moved the CM Pros home.
A good friend loves his comfort grip MACs and only likes his MAC branded Durateks, I'm the opposite and don't like the MAC comfort grips, but love the CM Pro/SK comfort grips. Granted, this damn website is the only reason I put so much thought into it. If not for here I'd probably still be hammering away at clear CM handles and have no complaints...
Damn, I get some coffee down and write a novel.
