DC73
Doing a bit of interior remodeling. I'll be replacing a builders grade zero clearance fireplace. Leaning towards a direct vent natural gas fireplace but may end up with another wood burning model. In either case, I want to plan for a blower and any other electrical need.
The garage is on the other side of the wall the fireplace is on. There is a GFCI outlet in the garage just behind the fireplace. It's in a perfect location to get power to the fireplace. This particular GFCI outlet has nothing connected to the load terminals. There is one feed to the line terminals and nothing else in the box.
Questions:
1) Can I get the power for the fireplace from the load side of the existing garage GFCI outlet?
2) Would it be better to pigtail the GFCI outlet and tap for the fireplace ahead of the GFCI?
3) I am assuming the fireplace will have to hard wired. Correct?
4) Bare romex okay inside the fireplace chase or do I need wire in conduit?
5) Any other issues to be aware of?
Thanks much,
DC
Questions:
Thanks much,
DC
